Question about Amana Dryers
I Have an Amana gas dryer Mod-NDG8805AWW that only intermittently works. I took it apart to clean it and to observe the operation. The ignitor will light up, but the gas valve doesn't send gas through but maybe 1 in 20 -25 times you run it
    President:
  • 1,430 Answers
The problem is the dryer coils have failed. They are inexpensive and easy to replace. This video will walk you thru troubleshooting and replacing this. There are also videos of different styles to help with disassembling.
http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
Posted on Jun 02, 2010
Amana propane dryer ignitor works, gas starts then flame shuts off in 5 secs
hay bob , get your vent cleaned out ,there's not enough oxygen for the flame to stay on.good luck APPLIANCES R EN
Mar 03, 2013 | Amana Dryers
Ignitor works, lights the gas, then when the ignitor goes off, so does the flame.
Hi Stanley,
the problem with the dryer flame going out is caused by defective coils on the gas valve and the gas valve coils should be replaced
Dec 03, 2011 | Speed Queen Dryers
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
I have an Amana LEA30WA electric dryer. It runs but will not heat. I have it apart but do not know how to annilize problem
heatman101
Jul 22, 2011 | Amana Dryers
I have a model LGA30AL gas dryer. It will start up occasionally but will only stay lit for a short time. I have already replaced the Igniter. And found a small leak in gas line. I replaced that also. What...
The gas assembly consists of: The ignitor, the flame sensor, and the solenoid coils. The ignitor and flame sensor are either going to be good or bad no in between. The only thin in there that can get intermittent is them solenoids. They get hot and quit but after a long while they cool back down and work another time. themobilian_2450.jpg
Amana service Manual
Jun 14, 2011 | Amana Dryers
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Amana Dryers
I have a AMANA gas dryer model LGA80AW and it is not heating. I took the front panel off cleaned the lint from within the cabinet and exhaust pipe. What I've noticed is that the starter comes on and lights...
When you say "starter" I assume you are talking about the "ignitor" and it is glowing.If the ignitor stays glowing continuously then the radiant heat sensor, normally closed, is not opening OR if the ignitor lights up than turns off after about 10 seconds but no flame, then the coils (doesn't matter which one of the two) are bad. The coils are located on top of the gas valve and the radiant sensor is located on the side of the burner chute....Good Luck
The Squirrel
Mar 26, 2009 | Amana Dryers
Dryer shuts off during drying operation and fails to restart.
reach inside and turn the drum. If it ain't easy as pie to turn then something is casing the motor to get hot and quit.Check slides and rollers.
Feb 13, 2009 | Amana ALG643RB Gas Dryer
Dryers Logo
137 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
