Question about Americh Madison 2 6036 Bath Tub
My americh spa tub sounds like the motor is running but no air comes out of the jets.
  • 299 Answers
Make sure the filter isn't blocked and that the air control is turned fully on.
Posted on Jun 03, 2010
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
How do you remove and clean, or where do you find replacement jet knobs for americh jetted tub?
their jets un-thread counter clockwise. you will need to contact Americh directly. they will be able to sell you new jet trim.
Feb 19, 2011 | Americh Madison 2 6036 Bath Tub
No I don't think so.\r\nI have an Americh 6 jet
If you have hard water you will get lots of crud build up in the pipes.
Try soaking the jets in the cheapest vinagar you can find. The weak acid in the vinagar is great for getting crud off plumbing. Let it soak for at least 15 min then give it a try.
If this frees it up a little try the cheapest dishwasher powder you can get. The cheap stuff is a little abrasive and works great at cleaning jets.
Jun 05, 2010 | Home
Air blower does not come on after taking a bath to dry jet plumbing. Blower does work if blower button is depressed.
water has to be a certain depth, and the dryer blower I think comes on much later,what do the directions say?
Feb 27, 2010 | Americh Madison II Tub - 7236
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Cracked housing to underwater tub light
I belive but am not positive that those lamp assemblies are required to be low voltage. In other words, there is no safety issue if water contacts the builb or wiring. Call Americh to verify. The lens ought to be easily replaceable so as allow for bulb replacement. Ask Americh.
Jul 11, 2009 | Home
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Americh Madison 2 6036 Bath Tub Logo
Top Americh Home Experts
john h
Tom Chichester
Are you an Americh Home Expert? Answer questions, earn points and help others
