Question about Ryobi Garden
I have a new Ryobi RBC30SET which has had 2 tanks of petrol and wont start now. It fires now I put a new NGK plug with 100% good spark but won't run/ open up.The 2 H+L adjust screws are Vslots (anti tamper)I am an Engineer and was going to cut 2 slots but they look like ball valves unthreaded?
  • 246 Answers
SOURCE: Engine will only run on 1/2 Choke
Hello edv40026:
Have you Checked the Exhaust Port and Muffler for Restriction?
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect or the Compression is Low (Worn Rings/Cylinder).
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi CS30 will start but when I pull on the
Check the fuel lines first for cracks. If they are cracked or brittle, replace them. Also, your carburetor may need cleaned. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals. Make sure the small screen in carb. is free of debris. The smallest of particles can cause your problem. Reassemble and try starting. If it still acts up after all this then you will have to purchase a carb. kit and replace all appropriate parts. If you need tips on these remedies, feel free to ask.
Jim
Posted on May 30, 2009
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
bbreton
  • 437 Answers
SOURCE: ryobi rht266oda 26cc petrol hedge trimmer. runs
You may need to take it to a professional to sharpen. It may have some trash in between the blades keeping it from not cutting. Plus when you use it try spraying some WD40 on the blades to help them move and cut.
Posted on Sep 29, 2009
harlan301
  • 205 Answers
SOURCE: my stihl fs 350 wont start at all now
if your fuel was bad, you have oxdashion in the sys. check your spark and compreshion. no less than 78pds if all is good, RR carborator over haul it, no if and or buts. this is an EPA Carb. flush tank line carb and get the oxdashion out. set each screw to 1 to 2 turns out and adjust the idl frist than the high side at full throttal untell engine smothes out
Posted on Oct 11, 2009
I have a Ryobi 30562 it wont start
Check spark arrestor on the muffler to see if it is clogged.
If not clogged remove muffler and check the piston and cylinder condition. Check for struck rings.
Note: These engine requires at least 100 psi to start so a compression test isn't out the question.
Mar 22, 2015 | Ryobi Garden
Peugeot speedfight wont start
Hi, Michellebym and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch, kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Peugeot Speedfight 2 Wont start
Peugeot speedfight 2 50cc won start Need help ASAP please
PEUGEOT SpeedFight 3 Workshop Manual
Peugeot SPEEDFIGHT 100 cc 1998 Parts
PEUGEOT Speedfight 2 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 29, 2017 | 2007 Peugeot Speedfight Motorsport 50
Ryobi SS26 trimmer won't fire
Are you using a new plug,sometimes a used plug look's good,but doesn't work.
Jul 08, 2017 | Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
I put 2 stroke and unleaded mixed in my dt 125 but i have a seperate tank for 2 stroke,it started to smoke then cut out and now it isnt starting and is not gettin a spark
Putting fuel mixed with the oil shouldn't hurt anything, you must have just fouled the plug, get a new plug in there and see if it fires. NGK is the best for 2 stroke.. If it fouls out again, drain the tank or most of it and put in fresh gas, it should clear up. The mix is very slight with the injectors running, I had oil injection on my old Saab and used to put in the premix all the time just in case, always had extra plugs with me cause they always fouled out. My wife would come home and say whats for dinner, i would have the spark plugs in the oven baking.
Feb 28, 2011 | 2000 Yamaha DT 125 R
Bike stops repeatedly after every 2, 3 Kms like petrol is over and starts again in 1 or 2 seconds. i changed my spark plug and its cap, magnet coil but the problem presists.
clean your carburetor and airfilters.then replace Your spark with NGK.i prefer NGK..clean ur fuel tank also maybe some dust particles of petrol can be there in tank also.check the flow of petrol from tank.if problem persists check your starting coil,rectifiers and wiring.and tel me onething at wat speed the bike is getting stopped?mail me vishnuyzf@gmail.com
Dec 29, 2010 | 2006 Hero Honda Super Splendor
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Got a loncin explorer 90cc quad had trouble with starting it, since i bought it from new. took it back got a new battery and starter fitted at cost was fine for a week or so, but now wont start again, its...
ive bought 1 and had the same problem , change the spark plug for an ngk , and use shell v-power petrol ( or any other high octane fuel ) myn now starts first time every time :) and go's like stink also consider buying a better battery , the standard 1's are **** !
Mar 16, 2009 | Cycling
2004 GMC sierra cylinder miss fire code
Have you put new sparks plugs in it. If you havent I would try them first. Only run the ac delco plugs listed for the truck. I have had many people come threw the shop with misfiring and trucks running like **** and come to find out they put bosch or ngk plugs in it. Your manual says there good for 100,000 miles but there really only good for about 75,000 or so. Also run some lucas fuel treatment or b12 chemtool. both you ad straight to the gas tank. If it calls for one can for 20 gallons buy two and double the treatment it wont hurt you engine.
Jan 31, 2009 | 2004 GMC Sierra 2500
Garden Logo
156 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
