Question about Swintec 401DPS Calculator
HOW TO FIX PAPER IN CALCULATOR?
Swintec 401dps electronic calculator i need to know how to put the paper into the machine.
Swintec 2640 Typing wrong characters
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
DickyO
Mar 17, 2014 | Swintec 2640 Electronic Display Typewriter
Swintec calculator manuals
You can order a manual from the manufacturer at
http://www.swintec.com/133-swintec-401-dps-manual.html
Sep 26, 2010 | Swintec 401DPS Calculator
Cannot load paper into feed into machine
Put new roll of paper on paper arm with the end of the paper hanging down from the back. Insert the paper into the **** at the back of the calculator - you need to look carefully as it is not very wide. Use the feed key to feed the paper through. Hope this helps.
Oct 25, 2009 | Canon P23-DHV Calculator
Swintec SW20 Portable Cash Register Paper feeding
please confirm that paper path is clear from any foregin object droped inside(pins-stapler-small pieces of torn paper).
regarding manual you can buy it on line(it is not free of charge).
Jun 29, 2008 | Office Equipment & Supplies
I know i know
Had the same problem. The tape does not feed through the top of the machine but instead through the slot at the back of the machine. It looks odd, but that is where it goes.
Oct 01, 2007 | Sharp EL-2630P Calculator
Swintec 401DPS Calculator Logo
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
