Question about RCA F36665 36" TV
I need to know the amp rating, on the fuse. And what to do, after I replace it, And you hear a sizzling and it blows the fuse again. The one I replaced had 5 amp. but not sure if it was a factory fuse. Or if someone else as been inside before me.All I had was A 1amp to test it with.I ohm the power cord does not show to be shorted. What would be the next step in trouble shooting? Before the the set went dead, there was a power surge
  • rbdg39 Jun 03, 2010
    I would like too know if the fly back transformer, is suppose to have metal sticking out the side. Mine has two spots.close too one another.Looks like it tried to seep out. Or is this, the way it's made? one is the size of a pencil lead and the other a small eraser.Its a f36665 36" RCA TV 1999 year.I just wanted to make sure I bought the right part to fix it.The Horizontal IC card didn't seem to look burned anywhere.Is this also called the regulator Ic or is this two different peaces? I had, a power surge, of course the fuse blew. I have too pick one up. All I had was the 1 amp, I need a 5 amp when I plugged it in, the TV sizzled and blew the 1 amp just didn't want to spend A lot of money on TV and still not fix the problem. thanks Rob
    Genius:
  • RCA Master
  • 1,550 Answers
The 5 amp is the most common one,replace with other with the same amp.But if they burn out the device got a shortcircuit,could be the horizontal IC the regulator Ic
Posted on Jun 02, 2010
Testimonial: "very helpful thanks"
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
Automatic transmission not shifting gears
Replacing any fuse after it has blown ,your almost
guaranteed it will blow again
At least you know the circuit with the problem
Now you go to factory wiring diagrams, to see what that
fuse controls & do some testing
Have to have wiring diagrams,be able to read them & know
basic electricity & be able to test your vehicle,then you have
to be able to continue on with professional tools, once the fuse
issue is resolved, if the fuse keeps blowing every few days
You could have wiring issues,more likely inside the trans in the oily
environment ,you could have solenoid or module failure or mechanical trans issues
I would say you can't resolve at home,need professional help
Mar 14, 2014 | Ford Expedition Cars & Trucks
What type of line fuse should i use with krell S-300i integrated amp.
Depending on the design the fuse rating could be on the board, or if you have the original fuse on the case. Say it says 5A then you can replace it with anything up to 5 amps. The type's not that important. A quick blow will do the trick. If it goes again, it's likely to be a shorted part that's causing it.
Apr 19, 2013 | Audio Players & Recorders
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
My circuit board on my tevion surrond sound has blown a fuse can i get a replacement for it
Yes you can and when you replace the fuse and it blows again then you have a fault that is causing to blow.
The fuse has an amp rating and this is marked on the end cap, replace the fuse with the same amp rating.
Apr 26, 2011 | Computers & Internet
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Ht-r500 onkyo
When a receiver does this, it is know as the "protect mode". This keeps the receiver from causing more damage to the components in it, by shutting it off when it detects an abnormal amount of voltage or current.
If you had to replace the fuses, it is most likely that you have a blown channel in the receiver.
You put 8 amp fuses in, so I hope that the fuses that blew were 8 amps as well. If you put fuses in that are higher rated in amps than the ones that blew, you will most likely cause more damage to the unit than need be. If the fuses keep blowing, please stop putting new fuses in again until the unit is repaired. Every time a fuse blows, it is because of too much current is going thru the unit. Having too much current is a very bad thing for electronics, it causes components to short out and sometimes even catch fire if the fuse is higher rated than it is supposed to be.
To find out just what parts will need to be replaced, you need a multimeter and then you will need soldering tools to remove the bad parts and put the new ones in.
When an amplifier channel gets blown, there are normally around 5 to 10 parts that will need to be replaced. If you do not replace every single bad part in the channel that has blown, you will most times blow up all the new parts that you just put in.
If you have no experience with electronics, you really should take it in to a service center for repair. If you are willing to try it yourself, let me know and I will guide you thru the troubleshooting steps to help you identify all the faulty components.
Onkyo is very well made equipment and is worth getting fixed.
A blown channel can normally be repaired for around $100 to $150, just depending on the shops rates and the extent of the damage.
Let me know if you need more help.
Dave
Jul 26, 2008 | Onkyo HTR500 Receiver
Denon PMA 520 fuse blown
Check that you are replacing the fuse with the correct type first. Fuses marked with a T following the rating are "slo blo" fuses and if a fast blow is used instead, it will fail again at turn on. Otherwise, the amp will have a fault occurring, probably in the output stages. You should refer this type of fault to a repair guy that knows HiFi. as this sort of repair needs an experienced touch.
Jan 05, 2008 | Audio Players & Recorders
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
RCA F36665 36" TV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
