Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Bottom of freezer compartmant door has ice build-up. unable to remove wire storage bin. Frozen to the bottom of the unit.
  • 4,793 Answers
You may have an air leak on the bottom of the door so you will get a buildup of ice.do a full defrost,check door seals fit,as a first step.
Posted on Jun 02, 2010
HOW TO REMOVE ICE MAKER STORAGE BIN ASSEMBLY IN FREEZER
empty freezer put a pot of boiling water under the ice bin and let it melt it
May 10, 2016 | Refrigerators
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
Jun 18, 2014 | KitchenAid KBFA25ER Bottom Freezer French...
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Csx22br freezer ice build up water runs out bottom of freezer
Your defrost drain hole may be plugged or frozen over. Open the freezer door and remove the lower shelf and basket so you can get to the back evaporator cover, and right under it is the drain hole. Remove what ice may be built up and pour very hot water into drain. It helps to have a syringe to remove the water and pour more hot water into drain. Then use a wire or other flexible tubing to poke into drain to clear restriction then flush with water.
Oct 30, 2011 | Hotpoint Refrigerators
Ice not dispensing from door. There is ice in the cabinet.
look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
Jan 02, 2011 | Maytag MBF2256H Bottom Freezer...
Water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
May 27, 2009 | LG LRFD25850 Stainless Steel French Door...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Bottom Freezer question
Check first that you do not have a build up of ice. Then check that the Wire rack has not become distorted or something has become unclipped on it.
Oct 07, 2007 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
93 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
