Question about Microsoft Windows Server Standard 2003 for PC
Shut down services
How to enable welcome screen shut down services in windows 2003 server.
  • Arut selvan
    Arut selvan Apr 10, 2008
    Good, But I'm asking for windows 2003 server.
    Scholar:
  • 50 Answers
If you are using Windows XP, follow these steps.
Open your Control Panel, click "Performance and Maintenance", and then go to "Administrative Tools". Go to "Local Security Policy".
Under 'Security Settings' -> 'Local Policies' -> 'Security Options', find "Shutdown: Allow System to be shut down without having to log on" and enable it.
That should take care of it.
Posted on Apr 09, 2008
  • Shannon Mantel Apr 10, 2008
    Alright, that one should be similar. I don't have access to that OS immediately.. (I'm not at work). It should be almost identical.
    Use your Group Policy Editor instead. Type gpedit.msc into the Run dialog box. Go to Computer Configuration, Windows Settings, Security Settings, Local Policies, Security Options. (Same path as I listed above). Look for "Allow System to be shut down without having to log on", and right click the string to change the value. Obviously, you want it to be "enabled".. That should do it!
How to Install Windows Server 2003?
what you have to do is to wait as the Windows Setup screen loads. Hit the "Enter" button once the "Welcome to Setup" message appears. Read the Windows Licensing Agreement and hit the "F8" button to agree to the terms and continue to the next screen. Create the partition on your hard drive where you will install Windows Server 2003.
Oct 20, 2016 | Computers & Internet
What are the causes, of a desktop pc not restarting when selecting "restart" from the shut down menu on pc that is running windows xp professional spk3?
This was the successful answer to almost the same question found on Microsoft's support forum (copied and pasted here):
Method 1:
I would suggest you to do a SFC (System File Checker) scan on the system and check whether the issue is resolved. Follow the steps mentioned below.
a.Click Start, click Run, type cmd and click ok.
b.On the command prompt, type sfc /scannow and hit enter.
c.Once the scan is complete, restart the computer and check if the issue persists.
Note: You will be prompted to insert the Windows XP disc if any file is missing.
Description of Windows XP and Windows Server 2003 System File Checker (Sfc.exe)
http://support.microsoft.com/kb/310747
Method 2:
I would suggest you to do a system restore to the point when the system was working fine and check whether the issue is resolved. Follow the steps mentioned below.
How to restore Windows XP to a previous state
http://support.microsoft.com/kb/306084/en-us
May 23, 2014 | Microsoft Windows XP Professional With...
I cannot get drivers to my Windows server 2003 for hp deskjet printer f380
Hello and Welcome to FixYa!
Here is the link from where you can download the drivers (Windows XP) that will work with Windows 2003 Server.
Click Here
Select Windows XP from the list, download and install that driver... It is compatible with Windows 2003 server edition...
Best of Luck,
Please Do RATE the solution, if found helpful,
Concerned.
Jul 06, 2010 | Computers & Internet
I want to install a mixer device
Sound options are disabled for Windows server 2003. You have to enable sound and audio services using the "Services" panel. You can install that and then Enable the services. After installing click on Start - > Run -> Type in services.msc and hit enter key. Then scroll the list and find the related Service. Right click on it and go to Properties. Then select "Enable". Set the Startup mode to "Automatic".
Jul 08, 2010 | Microsoft Windows Server 2003 Standard...
DNS
If the Windows 2003 server is utilized as the DNS server, then yes it should be set to 192.168.1.5. You need to get into the Linksys router via http://192.168.1.1 and under DNS of DHCP if it is set to .1.1. You should be able to change it to .1.5.
Dec 07, 2009 | Microsoft Windows Server Standard 2003 for...
Tell me latest update for service pack
Windows Server 2003 Service Pack 2 (32-bit x86)
Microsoft Windows Server 2003 Service Pack 2 (SP2) is a cumulative service pack that includes the latest updates and provides enhancements to security and stability. 3/12/2007 73 From: http://www.microsoft.com/downloads
March 12, 2007 Windows Server 2003 Service Pack 2 (32-bit x86)
Sep 18, 2009 | Microsoft Windows Server Standard 2003 for...
DNS Deligation
hi,
the above attached a link document is for windows 2000 server not for 2003.
ramana
May 22, 2008 | Microsoft Windows Server Standard 2003 for...
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
