Question about Brother MFC-8220 Fax
I can print on legal size paper but when I load letter 8.5x11 I get a check paper, reload paper message and no success in printing.
  • dougboedecke Jun 02, 2010
    Great advice, took me through a couple of steps and the machine is working... for now.
    President:
  • 1,188 Answers
This is because you are loading sheets incorrectly or the the paper sticks and is out of specs. Please follow the correct procedure on page 42 of the user manual. Click here to open a pdf copy.
To remove this error do as follows:
  1. Pull the paper cassette tray completely out of the machine.
  2. Remover paper from the tray.
  3. Verify the paper width and length adjuster for the paper size you want are set accurately (squeeze and slide the adjusters to the correct width and length).
  4. Fan the paper well. Reload the paper in the paper cassette tray. The tray can hold up to 250 sheets of 20lb paper. Press down on the paper to flatten it in all four corners, keeping the paper level below the guide (located on the right side of the tray).
Please keep in mind that the sheets must not stick and the adjusters should be adequately set.
Posted on Jun 02, 2010
  • 1 more comment
    thank you, that got read of the check/load paper message. I had only set the tab for the correct size not the sliding bottom part of the tray. Now I'm getting a paper jam message but I can't see a paper jam anywhere.
  • Adnan Bhatti
    Adnan Bhatti Jun 02, 2010
    Are you sure you did all the paper loading steps according to official instructions? You should not get a paper jam error if you did it right. Please note that you should check for any previous remnants which may have slid through and onto the toner or drum. This message is also displayed if somehow the machine is unable to pick paper from the tray.
    I will paste the instructions word to word below, please go through them and I'm sure your machine will be up and running in a few minutes:
    Paper jams can result from a variety of
    causes. One
    of the most common problems is the type of paper used in the machine.
    Please
    verify that the paper being used meets the recommended paper
    specifications:
    Paper Tray
    • Paper type:Plain paper, recycled
      paper and transparencies
    • Paper size:A4, Letter, Legal, B5, Executive, A5, A6, B6
    • Weight: 16 - 28 lb
    • Maximum paper tray capacity: Approximately 250 sheets of 20
      lb plain
      paper
    Manual Feed Slot
      paper and transparencies, envelopes
    • Paper size:Width: 2.75 - 8.66 inches
    • Height: 4.57 - 16.00 inches
    • Weight: 16 - 43 lb
    • Single Sheet Feed
    If the paper meets these specifications
    and PAPER JAM indications are still
    occurring, please follow these steps:
    1.Turn off the Brother machine using
    the On/Off switch located on the lower
    right side.
    2. Pull the paper tray, located in the
    bottom-front of the machine,
    completely out.
    3.Remove any crinkled or damaged sheets
    and discard them.
    4.Remove any paper remaining in the
    tray.
    5.There are two blue paper guides
    located on the either side of the paper
    tray. These guides are used to adjust the tray to fit the width ofthe
    paper.
    Squeeze the paper guide located on the right side of the trayto make any
    necessary adjustments. Check that the guides are firmly in the slots
    located on
    the bottom of the tray.
    6.The blue plastic paper guide located
    in the center back of the tray isused
    to adjust for the length of the paper. Squeeze the paper guide and
    adjust to fit
    the length of the paper. Verify that the guide has locked into place.
    NOTE:
    If using legal size paper you must
    first extend the tray in the back, press the blue guide release button
    located
    on the right rear sideof the tray and pull the back of the tray out.
    7.Put the paper in the paper tray. The
    side to be printed on must be face
    down. The paper tray can up to 250 sheets (20 lb. paper)
    9. Reinstall the paper tray firmly back
    in the Brother machine.
    10.Remove the tray once again to verify
    that the rear guide has not slipped
    when the tray was installed. If it has slipped set it back in place and
    repeat
    the tray installation process. Check again to see if ithas slipped. If
    the rear
    tab will not remain seated securely, please contact our Customer Service
    Center
    at 1-877-Brother (1-877-276-8437) Monday through Friday, excluding
    holidays.
    11.Reinstall the paper tray.
    12.Press the cover release button
    located in the front of the machine below
    the Output Tray Support Flap and extension and opens the front cover.
    13.Remove the drum assembly by lifting
    it slightly and pulling it out. If the
    drum does not come out easily skip to STEP 20.
    14.With the drum assembly removed pull
    any jammed paper up and out of the
    Brother machine..
    15.Remove the toner from the drum by
    holding down the lock lever (blue tab)
    on the right side of the drum assembly and lift the toner out.
    NOTE:
    Handle the toner cartridge
    carefully. If toner scatters on your hands or clothes, immediately wash
    it off
    with cold water.
    16.Remove any small pieces of paper
    jammed inside the drum.
    *This is an important step. Look very
    carefully for any small piece of paper
    thatmay be stuck in the drum.
    17.Reinstall the toner into the drum.
    18.Reinstall the drum assembly into the
    machine.
    19.Close the front cover, pressing
    firmly on each side until the cover clicks
    into place.
    20.Open the output tray located in the
    back of the machine.
    21.Pull out any jammed paper.
    22.If you are unable to clear the jam,
    open the Black Jam Clear Cover located
    at the bottom of the fuser unit. There are two rectangular slotslocated
    on the
    cover. To open it, place you finger in the larger slot located on the
    left side
    and slide the cover to the left and press it down.
    23.There are two blue pressure release
    levers, one on each side of the fuser
    unit. Pull these back and down to release the pressure roller inside the
    fuser
    unit and allow the paper to slide out freely.
    24.After removing the jam, push the Jam
    Clear Cover back in position by
    lifting it up.
    25.Return the Pressure Release levers
    to their original positions.
    26.Close the back output tray.
    27.Power the machine back on.
    28.Test by making a copy. Place a
    document face down in the ADF. Press the
    COPY mode key located below the LCD display and press
    START. "
    Source
    got it, thanks again. Not sure what was causing it, did most of the steps, it wasn't picking up paper, think the slide adjustments might have been it.
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Cannot print Legal size on Canon IR2420L
LEGAL SIZE IS LGL THAT MEANING 8.5/14 INCH. IF YOU WANT TO PRINT CHECK THE SIZE OF THE PAPER, FLSC IS EQUAL TO 8.5/13
Apr 22, 2014 | Canon Office Equipment & Supplies
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
Cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
Reload paper error
Listen for the paper tray is popping up when you push it in.
Remove the paper tray completly and look for paper in the cavity.
Jun 24, 2008 | Brother MFC-8220 Fax
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Brother MFC-8220 Fax Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
