Question about Kenmore Washing Machines
Flashing F-21 and SD wont finish a load - Kenmore Washing Machines
  • Kenmore Master
  • 8,220 Answers
Your washer is designed to use a TINY amount of water. This conserves water and takes less energy to heat the water. Since it is so little water used any amount above a teaspoonful of detergent will reek havoc with the delicate controls on the machine. F21 Long drain Possible cause: Clogged filter, clogged/failed pump.flashing F-21 and SD wont finish a load - 82f0c42.jpg Sud= Suds lock detergent overdose. Too much detergent, the wrong stuff, added to the wrong compartment, you gotta use HE soap and you gotta use the correct amount. You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water a9be475.jpg
used in HE machines, it is important
to use an HE detergent (low sudsing)
which is specially formulated to work
best under these conditions. The two
most important considerations
of a front loading washer are suds
control and soil concentration.
First, the tumbling action in an
HE machine generates
more suds than a top loader.
Tumbling the clothes in and out of the
water breaks the water surface
causing air to be trapped in the solution,
creating suds or foam. Multiple problems
can occur from oversudsing, such as
flooding from suds overflowing out of
the machine, formation of a suds cushion
during the tumbling action which reduces
mechanical energy,and “suds lock” which prevents
the machine from effectively spinning out the
water. In the situation of suds lock, the
machine trys to FIX the foaming problema by
stopping the cycle momentarily to allow
the suds to dissipate and then adding cold
water. This routine the machine goes
through to correct for over-sudsing results
in loss of energy and water savings and
can significantly lengthen the cycle time
(sometimes by as much as 2x). HE detergents
prevent over-sudsing and allow for
better rinsing of suds. HE detergent matters in
soil management also. Though HE washers
use about 1/3 of the water of a
top loader, the concentration of soil in the
load is much higher due to the larger
loads. To handle the higher amount of
soil, many HE detergents are specially
formulated with soil suspending ingredients
to prevent soil from re-depositing
onto clothes. Only use detergent with HE marked on it.
Use the correct amount.
The technical data sheet along with that
pesky clogged pump is located behind the
toe kick panel; remove the screws under the
bottom front edge of the washer. Tip the appliance
back to get to them screws. With the screws
removed, the panel will comes down and off.
Posted on Jun 02, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have tried for two days to get on my netbook. It says on the screen Loading os Image.... What is happening. Unit is fully charged....
It has a problem finding your windows file to finish loading the CE image. If this is the SYNET07526, then follow the flashing TIP found at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Be sure to follow the information exactly and insure the SD card that you use is put in the SD slot UPSIDE DOWN.
Feb 16, 2011 | Sylvania G-Netbook
My washer wont drain, says SD and blinks f-21
Sd: Suds lock. Detergent overdose. Clean out the soap dispenser. Remove the bottom panel and open the pump drain. F21: Long drain. Possible cause: Clogged filter, clogged/failed pump. Run some loads without detergent then use these amounts:
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Apr 15, 2010 | Kenmore 43142 Front Load Washer
SD card wont load on my t-mobile G1
try to go to a free check up cellphone repair...
check if your sd card slot is working fine...
if not you know now what is the problem...
but before it...try to fix it by yourself...just make some little adjustments...
Feb 11, 2010 | Kingston 4GB Secure Digital High Capacity...
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
127 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
