Question about Nintendo DS Console
It will not charge the battery. The charger has been tested and works. bought new battery. ninetindo ds will not play even when plugged in
  • 140 Answers
You will need to check the fuses inside of ds.
Posted on Jun 02, 2010
My ds lite turns on but it will not charge. It's not the battery or the charger. I have tested the fuses with a multimeter and both fuses read 0 ohms. The orange charge light does not flash briefly when I...
You can try buying another battery, or by buying a charging station that could just charge your battery (incase its the charger port on the ds thats broken).
Feb 28, 2011 | Nintendo DS Lite Console
Unable to charge battery
Well, yes there is a solution to this, but it still will cost you some bucks.
This sounds like you have a bad battery.
Usually when you have a bad charger, the same things happen that you describe. Only difference is your system won't come back on if the battery has fully died.
In your situation the battery does come on, but not for long. Which leads me to believe your charger is still working, however your defective battery is only being charged to a certain level.
I would recommend you use another battery with the same charger and see if you get the same results.
IF YOU DO..
Try a different charger.
If you're still experiencing the same results with a new charger and battery, then I'm afraid the problem is your charging port. If so, you would have to have this system repaired.
I wish you luck and hope I helped!
- Great
Apr 13, 2010 | Nintendo DS Lite Console
Nintendo DS Battery charger
If its the charger that is it probably the charger its the battery. And a universal charger would work but try not to buy it off line if you can.
Jun 05, 2009 | Nintendo DS Lite
Nintendo DS Lite battery and power problems
take it to best buy or where you bought it and they might tell you whats wrong if they dont go to support.nintendo.com and put it in repair and it will cost $50-$90
May 22, 2009 | Nintendo DS Lite Console
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo DS Adapter
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Mar 26, 2008 | Nintendo DS Lite Console
My charger is not working (NOT DS LITE)
Check the fuse in the Plug ?
also give the connector to DS a little side to side wiggle, to see if it,s a bad connection.
Mike @ Compurepair.
Feb 23, 2008 | Nintendo DS Console
DS lite not working
there may be some kind of damage in the ds as i had the same problem it may have been shaken around or dropped or even faulty the best thing to do is send it back if you dont have the warranty then go to a gaming store most have a collection day where someone comes to pick up broken ds and takes them its free except tfor the repair.Its best if you dont fiddle around with it a it will become more damaged
Jan 05, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
