Question about Honda Garden
Honda mini tiller has no power. It will idle but bogs down at full throttle
SOURCE: Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Posted on Apr 09, 2009
  • 16 Answers
SOURCE: I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: My Honda mini tiller with a GX 31 engine starts
Clutch or transmission, a common problem with FG 100 series Honda.
Posted on Jun 05, 2010
  • 10865 Answers
SOURCE: Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Posted on Jun 16, 2010
I have a 1986 honda prelude2,0si pgm-fi programed fuel injection 12valve.my car in allgears starts bogging out,towards the end of gears.
1985 Vf750F - Bogs Down On Throttle - Maintenance Questions - VFR ...
www.vfrdiscussion.com > ... > Maintenance Questions
Jan 22, 2014 - 10 posts - ‎4 authors
Page 1 of 2 - 1985 Vf750F - Bogs Down On Throttle - posted in Maintenance Questions: Greetings VF braintrust! I have a 1985 VF750F which I ...
Honda Spree and Elite 50 Forums • View topic - 1986 honda spree ...
www.hondaspree.net/phpBB3/viewtopic.php?f=3&t=18521
Apr 9, 2011 - 12 posts - ‎4 authors
Hi all I am new to thie forum. I recently bought a used rebuild Honda Spree. The guy I bought it from ran super unleaded in it and mixes klotz ...
250 bogging down under full throttle. - Honda Rebel Forum
Dec 02, 2015 | Power Flow 1986 - 2001 Honda Prelude Mud...
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine stalls at high rpm.
Clean your filter, check your plugs and if it still cuts out tighten up your throttle adjustment while you have it idling until you find a good purr.
Jan 27, 2010 | Honda 25cc 4-cycle Mini Tiller
The engine cuts out after it heats up
This seems to be a common issue as of late, i'd tighten up your idle adjustment so you can run at full throttle with no issue. The tiller's oil should be at the lower lip of the dip stick's access threading while the unit is laying face down (gas tank down). Clean up your carb as well and change your plug/filter, if this doesn't work than you're probably looking at some simple carb adjustments, but the fact it dies after 10 minutes of use makes me think it's running either dirty or too rich.
Apr 19, 2009 | Honda 25cc 4-cycle Mini Tiller
Difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
Apr 05, 2009 | Mantis 2-Cycle Tiller
Mar 16, 2009 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
65 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
