IT TELLING ME MY dvdROM/CDROM IS NOT SURPORRTED ???
  • qwertqwert
    qwertqwert Jun 04, 2010
    What application is telling you this exactly? When did this start? Is it a new DVD-ROM? Further information would be greatly appreciated!
2 Suggested Answers
danasaur
  • 77 Answers
SOURCE: Change CDROM on Toshiba 2805 -s 202
IDE 1 is the CDRom (or any optical device attached). IDE 0 (zero) is the Hard drive. So this message is telling you there is a problem with the DVD/CD-Rom, that has halted the boot process. Now you have no choice but to go to BIOS (read startup screen to find the procedure, usually DEL, F2, or F12 keys) and see if the problem can be corrected there (or if not, disable the drive, save change, and try rebooting again). If this is not possible, then you might try booting from an external device (floppy, CD, USB etc) if your system allows that (and if you have the boot software/media). Otherwise, you must remove the drive, in order to regain your desktop (pass the halt stage in boot process). Here is how to remove the CD:
Underneath the laptop, there will be a screw about 4 inches in, on a centyer line direct from the DVD/CD tray panel. Remove this screw. Insert a pin or paper clip (carefully, and STRAIGHT in!) to the small hole next to the CD tray release button. This opens the tray manually. Pull it out to the full open position, then GENTLY pull further, and the whole drive will release from the laptop.
Once you have reached the desktop, you should try to remove the previous driver if possible, via start menu/settings/control panel/system (or r-click my computer and select properties). In system control panel, there is a hardware settings tab. Here you can remove or disable hardware. Try adding a "generic CD-Rom", so the DVD might get past boot process when you reinstall it (later, below).
Now, try to start the laptop without DVD/CD. If it starts normally, your driver change was incompatible, or possibly, in the process of changes you did something that impaired the drive or its ROM (or perhaps needs to be cleaned).
Now try reinstalling the CD Rom drive (no screws yet, just insert fully). If you are still at the same halt, you have cut yourself out of using this CD, unless perhaps tou can reboot with a windows CD while the drive is installed, and let windows detect and install a PROPER driver.
If that is not possible, you need another DVD/CD drive. You can also buy a replacement or cheap older model for testing system at any legitimate advanced PC shop, or many used computer parts stores. Try the drive before you buy, just slide in and mount a CD/DVD. (you may have a special adapter that must be removed from the old OEM drive and attached to new one, and the tray cover may need to be switched to allow the CD to close for testing)
Regardless of the outcome of any of the above, please post your results, and the complete text of the black boot screen here, so I can analyze the problem -or any other possibilities that may be indicated by the post dialog.
Posted on Mar 05, 2008
Connecting cdrom &dvdrom to A8M2N-LA m/b?
You may have to use the front Line Input connector F_LINE_IN1 in the corner. There doesn't appear to be a dedicated DVD audio input listed on the internal connector listing in the manual:-
http://h10010.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&dlc=en&docname=c00714578
Feb 26, 2014 | HP Nodus3 Motherboard Asus A8m2n-la 45...
My computer can read cd's but not dvd's the drive is philips CDD5301
you need a dvdrom.cdrom cannot play dvd while dvdrom can play all of them
Oct 29, 2010 | Philips Computers & Internet
How to open dvd or cd drive acer computer
1. There should be a button in the middle of the CDROM tray, click on it and it will eject the CDROM Tray.
2. Open My Computer> Right click on CD/DVDROM icon & click eject.
Mar 12, 2010 | Acer Aspire 5610-4648 Notebook
I have a Sony Vaio laptop, but no reboot disk. It tells me that Windows Resume Loader failed but will not let me use the arrow keys, how can I reboot with out a cd
You must enter the BIOS this is done by hitting F2 DEL or F1 It all depends on your make and model.
sometimes the Bios will tell you which key to hit and when to hit
once there goto the section labled Boot Sequence and make sure that your first boot priority is cdrom/dvdrom.make sure that this is done.
save work exiting bios.
make sure that you have some type of floppy or cdrom or dvdrom in slot.computer will then boot from there. look for fdisk AND MAKE SURE THAT ALL pARTIONS ARE MARKED ACTIVE.
Nov 15, 2009 | Computers & Internet
Can not boot dell 6650 from external dvd
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Oct 06, 2009 | Dell PowerEdge 6650 Server
My lenovo thinkcentre m57 doesn't read dvd. It does read cd. What can I do? In fact, when I insert a DVD the drive wait for a minute, and then in "My PC" says No disk in drive.
hi frnd..
Just update the drive firm ware from the vendors site... tat will solve the isssue .. if it doesnt then i m sorry u have to go for a new drive...
Sep 21, 2009 | Lenovo ThinkCentre M57 Desktop - Intel...
Cd rom will not eject
Take a metal paperclip, straighten it out. Look on the front of the CDRom tray there should be a tiny hole, insert straightened paperclip and push to eject the tray manually. If the CDRom is hidden behind a flap built into the case this will need opening or removing first. After this if the CDRom fails to eject the drive belt has gone slack, its easier and more cost effective to replace it with a DVDRom or Writer.
Jul 05, 2009 | Acer Computers & Internet
DVD/CDROM NOT WORKING
Hi, it appears that CDW/DVDRAM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Please click on this link http://support.microsoft.com/kb/929461/en-us and then delete the upper/lowerfilters which is blocking the CDW/DVDROM to appear on your windows.
Hope this helps!!!
Thanks
Sep 11, 2008 | Computers & Internet
Canon pixma MP160
Hi, try this steps.
1. attached your printer in the computer, using the usb port maybe at the back or front of your system unit
2. turn your printer on.
3. put the installer cd in your cdrom or dvdrom
4. open it and follow the instruction while installation is going on
Jan 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
