Question about Dell Inspiron E1505 Notebook
I had a message that stated: TsSpckrp DrD+rw Ts-h632'ATA Device Installed What is this??? I did not install a new device. Was this included in a Windows update?
  • Dell Master
  • 11,800 Answers
Apparently the optical unit from your laptop (a Samsung btw)  has been reinstalled. This happens only when you have a bad connection to the motherboard. You will have to open the bottom of the case to inspect the data and power cables for the writer.
Posted on Jun 02, 2010
Sstcorpcddvdw ts-l632h ata device for toshiba is not working
This is the dvd player, it has died and must be replaced. A simple job that can be done by yourself - all you need to do is to buy a new unit
http://www.amazon.com/Toshiba-TS-L632H-DVD±RW-Notebook-Drive/dp/B001SKO552
and install it in the place of the old one - 2 screws and 2 cables to unhook and it's out.
May 21, 2011 | Computers & Internet
My tsstcorp cdw/dvd TS-H492C rom is not being displayed on my comp....it displays a message... Dat is windows successfully loaded the device driver for this hardware but cannot find the hardware device....
Hi
I see this is a month old,but I'll answer this for anyone doing a future search that may come across this thread.
The link is to Microsoft's on-line repair center.This will fix several error codes,including 41,and is probably the first thing to try when your optical drive is installed but Windows can't find it.
If this helps with your problem,and anyone in the future,would you rate my post please?
Thanks
Bob
http://support.microsoft.com/gp/cd_dvd_drive_problems
Jul 12, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
TSST corp DVD+-RW TS-L632H ATA device don' t work i installed norton security 360 and i had kaspersky in my computer and the device vas deleted
First, remove the AV that deleted the device. After that, right click to my computer, manage, device manager.
The on the right panel, right click on any device :scan for hardware changes.
Now the computer should find the device, and install the driver for it
Nov 18, 2009 | Dell Inspiron E1505 Notebook
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
TSST Corp CD/DVD RW TS-L632M ATA device wont play discs. Driver is current
I also have the TSST cd/dvd with the same problem but I just realized that is a comflict between all these programs I have installed (Windows Media Player, Sonic and Roxio Easy Creator 6). WMP will not even show it, then I went to Roxio audio central an it worked perfectly. I tried to change the default back to WMP but it wont take it. I believe this happens because Roxio was the last I installed and took control of the sound. Hope this help. I will be uninstalling my WMP and installing it again so that I can keep it as my first choice.
Apr 22, 2009 | Computers & Internet
System does not recognize CD/DVD Drive
The yellow triangle means there is no driver installed. There is 3 ways to get a driver. In most cases you right click on the hardware in Device Manager and download driver or reboot and Plug n Play should pick up driver automatically. If none of those work then the only option is to load it thru the add/removal in the control panel using the disc that accompanies the softeare.
Apr 01, 2009 | Dell Studio 15 Laptop
OPTIARC CD-RW CRX880A ATA DEVICE
if the cd/dvd drive is not listed in my computer or its if its not listed in device manager try this
delete the upper and lower filter from HKEY_LOCAL_MACHINE\SYSTEM
\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
once you click on the last folder to the right you will find upper or lower filters .....delete both and restart the computer and it should work
Jan 01, 2009 | HP Compaq Presario C500t Notebook
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
try to check in bios, is your dvd recognised in bios ?
if yes, it windows issues, try ms support :
http://support.microsoft.com/kb/314060
Feb 22, 2008 | Acer Aspire 3680 Laptop
Dell Inspiron E1505 Notebook Logo
125 people viewed this question
Alun Cox
