Question about Brother IntelliFAX 1270E Plain Paper Fax
Vertical black line on paper.. .I cleaned scanner and white roller with alcohol as instructed. . . thinner line, but still a line. There appears to be a groove in the white roller. Does the white roller need to be replaced or do I need to buy a new machine?
    President:
  • 3,085 Answers
Try a razor blade in the glass, spots can be hard to find
Posted on Jun 02, 2010
Printing colored lines
Vertical black lines:Check with another cartridge..Check Teflon sleeve.Vertical white lines:Replace cartridge.. replace transfer roller..Clean laser scanner unit( technical skills required) Horizontal Black lines:Replace cartridge..
Jan 31, 2012 | HP LaserJet 5000n Printer
Big black line on paper
clean the scanner, lift the auto doc feeder and underneath is a scanner, look to see if there is white out or some other obstruction and clean with a rag soaked with alcohol
May 21, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Everytime I scan, there are 2 vertical lines on appearing on the pdf file. I can't clean the stell roller as it's locked. can only clean the showing part.
You need to get to the scanner's Glass area and what you will sometimes find is some ink or white-out there all it takes is a small drop or smear to screw things up. Clean the glass with isopropyl alcohol, then some glass cleaner and the lines will go away.
Good Luck!
Rich Lilja
Dec 03, 2008 | Canon DR 2080C Path-Through Scanner
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Brother IntelliFAX 1270E Plain Paper Fax Logo
253 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
