Question about RIM BlackBerry Curve 8310 Smartphone
I cant save my mobile pictures. i take picture and it says file save error. i cant change it back to jpg
  • 76 Answers
Format the Memory Card
Posted on Jun 06, 2010
I've taken photos on my lenovo s8 but cant find them anywhere on my device xx
You can do a very general "search" on your machine. In the search box type " *.jpg" without the quotation marks. The asterisk is what is called a "wildcard", and will find all files with a .jpg suffix. .JPG files are going to be pictures. Beware, if you have a lot of photo's, it can take a while. Likely the pictures you saved will have odd file names, so explore them all... happy hunting!
Feb 08, 2015 | Lenovo Computers & Internet
During our visit to Paris/Disneyland we took more than 200 pics. However when loading them into our mac (into Iphoto) only 85 pics popped up. When I look at the SD card the majority of the pictures are...
Based on the file size, the files in question are probably RAW, not jpg files. Nikon View NX software or Photoshop will be able to open those files. You may want to convert them to jpg files, but do keep the RAW files since they contain much more picture detail then the jpg files.
Sep 01, 2011 | Nikon D70s Digital Camera
Paint cannot save file windows 2000 proffessional
This fix should allow you to use MS Paint to Open and Save JPG files, and Open and Save GIF files. The quality of the saved GIF with MS Paint may be reduced because of the limited 256-color palette (See here for an explanation and workaround). A better alternative for opening and saving JPG and GIF files would be to download and install a great FREE image viewer called IrfanView (MS Paint is still better for individual pixel editing, so it's good to have both).
If you want to proceed with the MS Paint Fix, you should first do a search on your hard drive to see if you
have the jpegim32.flt and gifimp32.flt filters.
You can find those files here:
http://www3.sympatico.ca/one.human/files/Jpegim32.flt
http://www3.sympatico.ca/one.human/files/Gifimp32.flt
You need to make sure you have both filters in the following folders:
C:\Program Files\Common Files\Microsoft Shared\grphflt
C:\Windows\MsApps\Grphflt
You may already have the JPEG Filter on your system, but only in one location. If that is the case, Copy and Paste it to the other location. Once you have the JPEG Filter in both locations, you may only need to do a simple Registry edit to be able to "Save As" a JPG.
If you already have the JPEG Graphics Filter on your system (and in both locations as stated above), but MS Paint still won't let you "Save As" JPG, you can manually edit the Registry to correct this. It's a simple fix. Go to Start, Run, type REGEDIT, and click OK. Go to this key by clicking the + signs beside the keys (folders):
HKEY_LOCAL_MACHINE\Software\Microsoft\Shared Tools\Graphics Filters\Export\JPEG.
Click on the "JPEG" key (folder) in the left pane, and you'll see a String Value in the right pane with the name "Extensions". Make sure under the "Data" column it shows only "jpg". If it shows "jpg, jpeg", double-click on the "Extensions" string and from the "Value data" field remove "jpeg" so that it only reads "jpg" (without the quotes).
If it worked, this edit allows you to "Save As" JPG. If it didn't work, or if you want to be able to also open and save GIF files, read on.
Or use this reg file to export your files as jpeg
http://www3.sympatico.ca/one.human/files/Filter_JPEG_Export.reg
Jul 29, 2009 | Intel Pentium III, 1.13 GHz...
Opening photos with EasyShare after uploading and saving
Do you see jagged lines across the picture?
If you have an Easyshare Software version 6.4 or higher - no matter where you move the picture or how many times you rename it, the software will detect it so if that gives the error msg that means the files are no longer in the computer.
How to check the version -> click on help beside gallery on the top menu bar and select About KOdak easyshare software.
If you have a lower version, the pics may still be there.
all your pics with *.jpg will be searched and you may see what you're looking for.
May 26, 2009 | Kodak EasyShare One Digital Camera
Cant send or recieve picture message without it saying configuration error
other extentions may not work on some operating systems
you can rename the file later if you want
Apr 22, 2009 | Samsung Modem Configuration Software...
Media Center file types
Yes, file extensions, .gif, .bitmap, .jpg are case sensitive. Just like if you tried to save a word document as .DOC then the file would look like test.DOC.doc. Change case and it will be fine.
Mar 02, 2009 | Microsoft Windows Vista Home Premium with...
Playback
saving .jpg/.JPEG/ .BMP file to a dvd disc don't wrie properly. try using a CD-R disc and save pctures as .jpg.
Jul 30, 2008 | Televison & Video
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Jun 14, 2007 | BenQ 5000U Scan to Web Scanner
RIM BlackBerry Curve 8310 Smartphone Logo
132 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
