Question about Naxa Electronics NX-579 TV
Volume on tv when turned all the way up is at a whisper
Volume on tv at a whisper even when i add external speaker the volume is the same on them, you can turn the volume down to nothing, but wont turn up. I have checked the mute button it takes the sound away completely and un mute restores it to whisper. Not sure of correct model but it is a 15 or 17 in with dvd, purchased at TA (truck stops of america). Tv is mounted in semi, your help is greatly appreciated.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
  • sweetpatti41 Jun 03, 2010
    i have tried resetting didn't work tried external speakers with the small jack volume output came thru the same way it did on internal speakers, and the external speakers were new, even plugged them into headphone jack, same response
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    OK, then as I said earlier it is an Audio IC or A/V Board the needs to be replaced. Please do accept the solution if the issue is resolved else post a comment for further assistance.
    Thanks
    Rylee
Pioneer vsx-454 not working propley.radio not even hissing,managed to get whisper sound via pc aux,i have cleaned inids?
It sounds like you're not in the right input source (mode) or you have a external source selected. I show your unit as a 1995 model and so check your Tape 1, Tape 2 selection buttons. These "Tape" selection button get dirty contacts that will kill the audio. To clean, with the volume low, press them on and off around 20 times each. This works the contacts back-n-forth and will help clean them.
Oct 31, 2012 | Pioneer VSX-454 Receiver
Extreme fluctuation of TV sound leval drives me nuts!!!!
arn't all french movies in whisper and dark screen mode?
I suggest using an amplifier ( yes an amp) reduce the volume on TV to just audible and plug in xtension line to an amp and set the volume on it. It is probably a faulty sound board in your unit. The use of an external amp will control it better by the audio out line.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Transparent French TV Commercials, Volume...
There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
May 21, 2010 | LG 26LG30 26 in. LCD TV
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
How to add more Sound, to my Sharp TV , even in the background, when watching movies, sound is very low , think its dew to cable service? Or would just like to Add external Rear Speakers?
The easiest would be installing a surround sound or other sound system that will amplify the audio. Also, some cable boxes actually have a volume control that is only found on the remote, try turning this up.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Brand new LC 42D65U
Sounds like your powerboard, take it back or call tech for replacement, dont settle for this, you paid good money for a working tv
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 19" LCD TV Volume is low on many channels even when turned all the way up as high as possible. I've checked sound settings, balance, etc. Don't know what else to do - can I add external...
The sound is just a bonus on big tv's anyways. If something went wrong, it not going to be an ez fix. Just use external audio. Better the audio burns out then the video.
Nov 14, 2008 | Sharp Televison & Video
Naxa Electronics NX-579 TV Logo
35 people viewed this question
Top Naxa Electronics Televison & Video Experts
Electro Med Services...
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
