Frigidare air conditioner thru wall unit Model FAH146Q2T2 leaking water inside?
  • 43,501 Answers
Always make sure that your unit is tipped back towards the outside os it does not leak inside...
heatman101
Posted on Jun 03, 2010
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
Thru the wall air conditioner is leaking droplets of water from between the frame and the body
Your unit should be pulled from the wall and cleaned. Also Check with a level that through the wall sleeve that the unit sits in has a slight lean towards the outside and not inside.
Jul 05, 2011 | Friedrich Heating & Cooling
Hello! I'm having some difficulty finding the drainage on this specific model. It's in my husband and I's bedroom....for the last two mornings we have found a puddle on the floor in front of...
Water leakages out the front are usually attributed to poor drainage. IE , the wall unit is not sloping slightly to the rear, or in the case of a split system, the drain hose is not directed down and away from inside. I would suggets checking the filters first. If the filters are blocked, and the cooling is set really low, its possible for the coil to start freezing and thus, leak water out the front. If the filters are clean and the coil is still freezing, you may have a gas shortage . Eventually when the gas runs out, the water leak will stop and the unit wont cool at all. If the system is working properly, on cooling mode, there should be cold air inside and the unit should be blowing hot air outside. If on heating mode, the reverse happens...
Jun 14, 2011 | General Electric AST05LK Thru-Wall/Window...
Water is leaking out the front of the unit
Water is a normal byproduct of the refrigeration process, Just like a glass of icewater has condensation on the outside of the glass.
The unit is designed to run the water outside. Check the slant of the unit, if it slants inside water will not exit outside..needs slight downward tip towards the outside.
Also check that the drain system is not plugged.
Nov 21, 2010 | GE AJHS08ASB Thru-Wall/Window Air...
Leaking condensate
There is dust and dirt in the drain hole...causing the water level to raise too high...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Heat Controller Thru-Wall/Window Air...
Leaking inside house , condensation or something causing liquid to leak inside house and i have to use towels to catch fluid
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
Jul 11, 2010 | Sunbeam SAW10CR1FHU Thru-Wall/Window Air...
Water is leaking inside the house
The drain that should be carrying the condensate water outside is stopped up. Compressed air works well to clear the drain.
Jun 22, 2010 | Sanyo 18KS52 Air Conditioner
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Frigidare thru-wall AC drips water when unit is on.
Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
300 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
