Question about Schwinn Mesa Gs Mountain Bike
Rusted chain and gears, rusted brake lines, cracks in brake pads
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
There is no quick fix, you need
new chain and gears
new brake lines
new brake pads
to stay safe
Posted on Jun 03, 2010
How do I fix my chain on my bike?
What do need help with?
Apr 17, 2015 | Cycling
Rear wheels are seized, feels like it always in gear but isn't. Can even tow it because they just slide
Rear brakes & parking brake are rusted
Take it all apart & remove the rust & work on the rear brakes
Front ones are rust also, I would guess
Probably never removed any rust or lube anything to do with
the pads & calipers in years
Apr 04, 2014 | Toyota Pickup Cars & Trucks
Is ther anything special about bleeding the disk brakes. I got some air the line when changing the brake pads.
Need engine running so ABS works
Need a helper slowly pushing brake pedal,
as you crack open the bleeders,have clear
vinyl tubing on them to a bottle
RR,LR,RF,LF
Do not let master run dry & LEAVE COVER
ON or you will squirt fluid all over everything
& ruin your day
Ratchet up rear parking brake, if you did
rear discs
You did remove ALL Rust from wheel brg hub face,
both sides of rotors,all caliper & pad sliding abutements
& use anti-seize where contact & sliding takes place
All rust etc from back of wheels
Machined rotors,no pads ever go on old worn suface,
the brakes will only make noise & long list of other problems
The anti-seize goes on everything,caliper bolt threads,back
of wheels,both sides of rotor mountings
Synthetic Brake Grease goes on caliper anchor pins or
or bolts & under rubber boots
Not the graphite stuff
While you at it, get the old trans & power steering fluid
out
They get done Every 30,000 miles & brake fluid every
2 years,spark plugs at 60,000, front (2) O2 Sensors
at 100,000
Jun 12, 2011 | 2006 Hyundai Tiburon
Also she feels like a palseating in pedal at 50-60 it's a 95 s10 blazer with 4.3 vortec
I f the car sits for any lenght of time the brake rotors. will rust except where the brake pads are sitting and as you drive it wipes the rust off and the rotr is slightly thinner where the rust was and the pads runing over the rotor ( bump ) over the thicker part of the rotor, so the brakes pulse under your foot. The rotors can be removed and turned at an auto parts store or you can just buy new ones. If the pads are thin you should change them too. get a look at the new ones while at the store with the rotors and if they look alot thicker get them too. The pads are sold in many different lines and you get what you pay for the better ones cost more. New rotors are better than turned ones depends on how much you can spend on your car. Of course you can pay a tire store or garage and even the dealer to do this work and you'll here many different prices. Some shops will lowball the price to get you in there and then sell you alot more after they get i torn down.
Jan 21, 2011 | Chevrolet Blazer Cars & Trucks
The breaks are sticking and have a burning smell the break lines, calipers, roaters and pads have all been replaced. The abs fuse was missing but one has been put in. What could the problem be?
On older machines the metal brackets that hold on to the floating calipers will rust. The rust squeezes the calipers and keeps them from floating. When you apply the breaks the caliper moves toward the disc but does not move away from the disc. The extra friction causes the discs to over heat, the brake fluid to over heat, and the brake pads to burn. Remove the calipers and the thin metal plates they slide on . Clean the rust off down to the metal so the calipers will float properly. Replace the pads and discs if necessary and bleed the system to remove the overheated brake fluid. Rust never sleeps.
Jan 20, 2011 | 1997 Dodge Caravan
2001 Dodge Dakota right front break keeps hanging up
this is caused by either the caliper piston seizing in its bore or the brake hose colapsing inside. remove the caliper and try to press the piston in with a c clamp. it should be very hard to move in according to your problem. now keep trying to press it in and crack the line at the caliper to allow some fluid to come out. if the piston moves now it is the line if not it is the caliper.
Jun 26, 2009 | 2001 Dodge Dakota
How to change rear brake pads
Raise the rear of the vehicle and make sure it is securely supported. Remove the rear wheel Remove the brake hose (A) from the suspension arm by removing the brake hose clip (B).Thoroughly clean the outside of the caliper to prevent dust and dirt from entering inside.Support the caliper with a piece of wire so that it does not hang from the brake se.f2d9a24.jpg
Remove the two guide rods (C) and caliper (D) from the bracket. Remove the pad shim (A) and brake pads (B).77fcb0a.jpg
Clean the caliper thoroughly; remove any rust, and check for grooves and cracks. Check the brake disc for damage and cracks. Install the pad retainers. Check the foreign material at the pad shim (A) and the back of the pads (B). Contaminated brake discs or pads reduce stopping ability. Keep grease off the discs and pads.3fdca95.jpg
Install the brake pads (B) and pad shim (A) on the caliper bracket. Install the inner pad with its wear indicator (C) facing down ward. If you are reusing the pads, always reinstall the brake pads in their original positions to prevent a momentary loss of braking efficiency. Rotate the caliper piston (A) clockwise into the cylinder, the align the cutout (B) in the piston with the tab (C) on the inner pad by turning the piston back. Lubricate the boot with rubber grease to avoid twisting the piston boot. If the piston boot is twisted, back it out so it is positioned properly.1d2811d.jpg
Install the brake caliper (D). Install and torque the guide rods (E) to proper specification. Install the brake hose (F) onto the suspension arm with the brake hose clip (G). After installation, check for leaks at hose and line joints and connections, and retighten if necessary. Depress the brake pedal several times to make sure the brakes work, then test-drive. Engagement of the brake may require a greater pedal stroke immediately after the brake pads have been replaced as a set. Several applications of the brake pedal will restore the normal pedal stroke.
May 31, 2009 | Hyundai Motor 2002 Elantra
LOUD sounds when braking(99 Corolla)
It is dust/rust and it comes from a low quality or a high carbon metalic brake pad or shoe. this problem can be corrected by using the OE manufacturer parts or the use of Ceramic pads/shoes. However don't be fooled by "Ceramic" on a box, it may just contain ceramic particals and not be a true ceramic pad/shoe. In over 16 years in automotive specialty repair I have found the PD line of the Wagner Thermo Quiet pads/shoes to be the best economical fix or the Top of the line Akebono Ceramic line will fix what ailes you.
May 25, 2009 | 2002 Toyota Corolla
Illustrations on how to fit front brake pads to 1999 ford mondeo
Just observe how you take the old ones off. Pads can only snap in one way. It may take some effort but clean the caliper of rust you shouldn't have any problem. Remember to crack open your brake fluid reservoir before compressing the caliper!
Mar 29, 2009 | 2000 Ford Focus
Leaking brake line
u can use metal pipe sections but not recommended may b cheaper to replace whole pipe certainly a lot easier t fit
Nov 21, 2008 | 1991 Buick Park Avenue
Schwinn Mesa Gs Mountain Bike Logo
156 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
