Question about HP Pavilion 523n (P9851AR#ABA) PC Desktop
HP Pavilion 523n PC desktop will not boot. System restore does not execute. No, don't have install disk. CD-Rom boots are not working either. Can you provide another option?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Prepare any bootable USB Drive with windows by expert and install it or change your CD-ROM
Posted on Jun 06, 2010
"disk boot failure, insert system
You should have a recovery cd, it will allow you to reinstall Windows. If you don't have even that then either borrow one from a friend and use it with you key (the one on the sticker), or order a new disk by following this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07143&cc=us&dlc=en&lc=en&product=90387
Jul 30, 2011 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
How do you install windows 7 on HP pavilian 754n? plz tell me quick because we just bought windows 7 and it doesnt work on the computer. thx you!
First you will need the Window 7 operating system cd.
place the cd in the cd room and let the auto run take place. this is not a quick process
it will take several minutes. If the operating system is not loading you may have a different problem
Jul 19, 2011 | HP Pavilion 754n PC Desktop
1) HP Pavilion a6300f went dead only fans spining, replaced mother board with same make model, now ssytem boots but windows don't come up. 2) tried up grade from Vista Home to Vista professional to save...
For the first one, you need to enter BIOS and set the HDD settings. Maybe you can automatic detect it once and then the system knew where to load system from. If it can see the hard disk and reads it but no operating system found, then you may need to check the operating system on your hard disk.
For the second one, I do think it is better to upgrade to a upper level OS such as Windows 7. While you have Vista you will have better deal with Windows 7. If you do have a agreement with Microsoft to have newer OS for free in a certain period, you can get Windows 7 for free. If you don't have that agreement, you can get Upgrade version of windows 7 with a huge discount if you have Vista.
You can actually back up your data to an wim file on vista and restore all the data and settings after the upgrading. But be sure to keep a full backup of your hard disk and everything just in case.
You can enter BIOS and make sure booting from CD first. Then there is a key you need to press very early in the booting process to launch the recovery. There is also a factory default restore you can use. Did you call HP to find out what the key is and how to use factory default restoration? You can always plug the hard disk to other computer to back up the data and then restore to factory default and put the data back.
Apr 23, 2011 | HP Pavilion Desktop a6300f Intel Pentium...
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
My hp pavilion 513n has completely stopped working! I need help!
Start the computer, and keep pressing F8 until you get a "boot" menu -- white text on a black screen.
Select "safe mode with command-line", and see if Windows will start.
If it does, enter 'CHKDSK C: /F' to get Windows to check the integrity of the file-system.
Then, find a friend with a genuine Microsoft Windows XP CD-ROM. Boot from that disk, and choose "repair", and see if the boot-process can "repair" your installed copy.
Jun 23, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
I have a Compac D300A Desktop you said for me to
If you want to boot your computer with disk you need to set first boot device as your cd or dvd rom.
For that when you power up the computer press F1 or F2 or "del" then you can enter in bios.
Then go to boot option then set first boot device as your cd ro dvd rom .then save settings and exit.
Then put disk in rom then it boot with that disk.
Let me know if you need more assistanse.
Thanks.
Sep 20, 2009 | HP Pavilion TX2000Z Notebook
I have a s3100n hp slim line pavillion and thru hp tech support was advised to do a system recovery. when i tryed to reboot my system some programs were missing and they hp said that i need the recovery...
You must go into the BIOS on boot up and choose to boot from CD-Rom instead of the hard drive. When you first turn on your machine and the HP comes up push F10 key to get into the BIOS. Look for boot priorities and put the CD/DVD Rom in the first boot position (directions on how to move these item up/down are at the bottom of the page)
Then your disks will be useful. Put one in and reboot. It should read you disc and follow instructions from there.
Hope this helps you, good luck
Apr 23, 2009 | HP Hewlett Packard Pavilion Slimline...
Hp computer
You can repair that by booting your system using the CD ROM and the select to repair windows.
If ever this will not solve then;
You should backup your files and reinstall the windows operating system.
In installing operating system you need the following:
1 windows bootable disc/ Operating System REcovery Disc
2.Cd /DVD rom
Boot your system any of this CD/DVD disc and then follow the on screen instruction.
After installation, don,t forget to install the drivers of your system that was enlosed in your system.
If ever there problem arising this solution please notify me for further support.
Jan 22, 2008 | HP Pavilion Media Center a1330n - AMD...
Loading songs on ipod
Usb 1 is not very slow, maybe computer system is busy doing some other services which is unknown to you.
if you plan to restore computer back to original state. you should back up first the important files(personal files any files that is important to you.)
system restore is not quite good except , you have an original windows system cd enclosed in your computer. doing this; insert cd and boot the computer using the cd.
If non of those; then you should provide windows cd and reinstall your windows: doing this; insert cd and boot the computer using the cd.
just follow the onscreen instructions.
some drivers of your computer notify me with the brand , model, motherboard details. if in case.
Dec 27, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
HP Pavilion 523n (P9851AR#ABA) PC Desktop Logo
226 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
