Question about Whirlpool Calypso GVW9959K Top Load Washer
Have a whirlpool calypso and it is staining my clothes with brown streaks. I can't even remove the stains from my clothes therefore loosing quite a few items. What is the problem and what can I do to fix it?
  • aj1108598 Jun 02, 2010
    I have a whirlpool calypso model #GVW9959KQ2 and it is staining my clothes with brown streaks. Does anyone know if the transmission on this model has replaceable seals or does the whole transmission have to be replaced?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be a bad door seal(part#9) in this picture as there is no separate transmission for this model:
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
    Wow that sounds like a much simpler problem easily fixable. Am I correct in that assumption?
  • Rylee Smith
    Rylee Smith Jun 02, 2010
    It can be if you know how to take it apart.
  • 4,066 Answers
Stains usually come from oil leaking from the transmission because of a failed seal. Post your model number. look - behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet. Some have replaceable seals and some you have to replace the transmission. If it's very old you should consider a new washer.
    Thanks! Do you know if my calypso model #GVW9959KQ2 has replaceable seals?
  • Charles T Nevin
    Charles T Nevin Jun 02, 2010
    Part 12 on this diagram is your u joint kit which is the closest thing you have to a transmission. It has lubrication in it. The kit comes with seals. If you determine that the staining is coming from this it doesn't look hard to replace. It's under the washplate and washplate dome. http://www.appliancepartspros.com/partse...
Calypso stains load
Hi there
I wonder why "dark streaks" on white towels. I presume that you have made sure that there is no dirt flying around in the machine.
Try to let the machine go a circle -without any washing in it- just to see if the water takes color. There are also in the shops washing powder
that remove stains of different types.
Also powder for "only whites"
good luck
Kolbrun
Apr 23, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stains my clothes. it looks like grease stains on delicate fabrics. plse advise. I checked many times and dont know where it is coming from. agnes
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore elite dryer burn marks on cloths
Mar 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Whirlpool Calypso GVW9959K Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
