Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
We have a fast drip coming from the drain, what does that mean?
  • 349 Answers
The pressure relief valve is going bad causing water to run out of drain line. They are easy to replace and they are a standard 3/4' threads. Turn power off and drain water down till no water comes out of drain if you lift the lever on the relief valve.
Lowes or Home Depot will carry a replacement for this heater. The T & P valve is a safety feature that will open if the pressue get's to high due to high heat in heater. With this you would get a blast of hot water running out.
T & P valve start to go bad they start dripping and evenually can not hold water back. This is a early sign for you to replace before it goes to running out.
Posted on Jun 05, 2010
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
Code 14 comes up on the remote what does that mean
Before calling Rheem or service technician, open following link for troubleshoot resources including error codes, Rheem chat, typical required maintenance manual, and possible product manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are start point for troubleshoot.
Error 14 is 'overheat wrap fault.'
This can include venting problem, failed heat exchanger, bad safety circuit, gas problem.
Rheem does not have a service manual posted for this specific problem.
Additional information: Tankless water heaters consume large amounts of gas during combustion. The combustion burns away hydrogen and the remaining poisonous byproduct is vented into the atmosphere at each home day and night.
Byproduct includes acidic water vapor that condenses along the vent pipe and drips back down vent.
Each tankless vent pipe has a drain line that directs acidic water into household drain.
If this drain line becomes clogged, or if vent was not installed correctly, then water drips down into heat exchanger and can erode or crack exchanger.
The typical maintenance manual above shows steps that can solve many tankless problems before they happen.
Sep 11, 2011 | Rheem Water Heaters
The computer code 14 comes up on the computer what does that mean.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Sep 11, 2011 | Rheem Tankless Water Heater Main Remote...
Water is dripping down one of the 3 feet under the heater. Does this mean it needs replacing?
make sure that the water is not coming from the over flow tube or the drain valve at the bottem of the tank first. If it is not then yes there is an internal leak and the tank should be replaced
Aug 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
A SMALL DRIP CONTINUES TO COMe out of the drain valve. I drained the tank and refilled it but it continues to drip. It appears there is a white plastic drain knob which is where I attach my hose to drain...
Hello CHUCK The drain can be replaced with a LONG stem brass hose bib.The plastic is a piece of s*#$.They also sell brass drain caps for a easy way out.Just screw it on.
Aug 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Flooded bathroom from top of unit
The T&P valve (temperature and pressure) relief valve is suppose to have a 3/4 in drain line threaded into it .This line should have ran to a trapped drain or possibly to the outside of the house. A water heater cannot over fill. To drain your water heater run a garden hose to the outside or to the lowest drain you have nearby.If its still wet be carfull not to get shocked,Attach the garden hose to the drain valve located towards the bottom of the water heater. turn the valve on. If water dosnt come out of the other end of the hose,youll have to see if you can run a peice of wire through the valve into the water heater to get it to drain. This can somtimes be a real problem . I usually leave the water on when i first connect the hose to the drain valve. This allows the water pressure to flush the sedament out of the bottom of the water heater.
Dec 04, 2009 | Water Heaters
Dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Jan 31, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
230 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
