Question about Whirlpool Dryers
I have a Whirlpool LER8858E02 Electric Dryer. Yesterday it worked fine. This morning when I push the start button, nothing happens. Is there a circuit breaker or override switch that needs to be reset?
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
  • 1073 Answers
SOURCE: whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
rickzilla
  • 706 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Posted on Sep 11, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
The digital panel does not start sometime
bad touch panel,everything is made of plastic,when you push the buttons in after a few times it can damage the touch panel,more so if someone pushes hard on the button
Feb 23, 2014 | Whirlpool GEW9868K Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Doesn't start
Check the door switch. Also it could be bad contact in the timer.
Jul 21, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Clean tough gas dryer
Probably, you are hearing the motor turning. The belt likely broke.
Dec 24, 2007 | Whirlpool GEQ9800P Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
