Question about Northstar Garden
I have a Northstar EPW model 157850B That does not spray with consistant pressure.
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
I do need the igniter for the burnner / my igniter i think it is the wrong one , it is too shot and the spray of oil do not fire/ i think the 'plugs' is little short to ignite on the spray , comes on and...
Send me a email at justin@wmpcs.com I am an dealer for Northstar and many other brands of pressure washers. I need the model number off the machine if you have it. I can get you the right parts for the machine. I might need a picture of what you are looking for or I could send you a parts breakdown of the machine and you could let me know what you need.
Nov 10, 2010 | Northstar Gas - Powered Wet Steam & Hot...
Looking for an electric starter for Northstar Model 157892A
Is this the engine model number or the machine model number? Is the motor already set-up with an electric start or is it something you are looking to add?
Oct 30, 2010 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
The spray stream is not consistent. After 2 - 3
The pump cycles to keep the pressure constant. It could be the impeller---they sell special ones to use with nonaqueous sprays--ie petroleum based. If petro was used at some time, the impeller might be bad.
Mar 01, 2010 | Northstar ATV Broadcast Spot Sprayer 16...
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Garden Logo
51 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
