Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Washer cycle not starting
I just bought a stackable from Best Buy, FLEB8200FS1. I am hoping FLEB8200DS is the same machine. The washer made a loud sound the other day, right before the final spin. It actually went off, I opened the lid, and there was still water in there. I moved the dial closer to the final spin, and the cycle completed. Now when I want to start a new cycle, either colored or whites, there is a humming sound and nothing going on. When I put the dial to the final spin, water comes out, slowly, and when I close the lid, the spin and drain cycle finishes.
    Genius:
  • 1,226 Answers
Did you read the user manual of your whasher? Unplug the washer to the wall out let and then verify carefully whats going on. maybe some unwanted material in it..check all the necessary components and test again.
notify me for what did you notice. melnavz
Posted on Apr 09, 2008
My stackable washer is sqealing just before spin cycle
Common cause of this problem is The sound at high speed spin due to dry bearing of motor and wash tub. lubricate with high temprature grease.If you are not able to do.contact the mechanic
Mar 02, 2015 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer Doesn't Dry Well: Take two full drying cycles.
if at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Mar 02, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
