Question about MidiLand Audio Players & Recorders
Constant hum and a strangs blown out sound if the volume and/or bass is to high! The hum is constant on or of powerwise. slightly louder when the system is off Model is Midiland MX-2 fantastic equalization of sound, thats why I would hate to replace it.
  • 14 Answers
SOURCE: Kicker L7 Repair
With the price of speakers dropping all the time it's really not worth repairing as it will cost too much to have it fixed by hand.
Posted on Dec 28, 2007
djnick989
  • 1067 Answers
SOURCE: X-230 Speakers Hum
bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Posted on Jan 16, 2008
SOURCE: 2005 buick leSabre whine or humming noise from front end.
I had the same problem with my 2000 Buick LeSabre last year. Took it in and they determined the wheel bearing needed to be replaced. Costs about $300 per bearing, but definitely needs to be replaced as you'd be in serious trouble if the thing went out at highway speeds.
Posted on Dec 11, 2008
SOURCE: Sunfire True Sub Constant Hum & Thump on Initial Signal
The problem in the subwoofer is at leat 4 bad components
degraded due to heat. Remove the module and ship to
Mr. Transistor 453 Opelika Rd. Auburn, Al 36830.
If your sub is thumping and not staying on at lower levels
I have the fix. Cost is $250.
Posted on Feb 09, 2009
etirbynnor
  • 655 Answers
SOURCE: Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Posted on Mar 29, 2009
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Pyle PPHP159WMU: Just received this used unit and the bass speaker tends to cut out the louder the volume is set. Does the battery have to be fully charged for the unit to function properly?
The speaker may have a current sensing device to avoid damage under high volume conditions. Also check the setting of your bass control. Every 3 db increase in setting doubles the power going to the driver and it is easy to over drive the unit at high volumes if your bass control is not on flat.
Feb 03, 2016 | Pyle Audio Players & Recorders
Woofer rattles at low volume...when i turn it up it sounds pretty good...still has bass and highs
May be a couple of things; The first is a resonance in the cabinet, which may not be noticeable at high volumes. If the speaker cabinet was ever dropped,or got cracked from dropping , dry weather,or whatever, there may be certain frequencies that make the cabinet rattle. Try holding the cabinet when it rattles and look for anything loose,from a side wall to a loose foot, or the speaker itself. Tighten up loose items and seal any gaps or cracks On the cabinet.
The other problem could be a partially blown speaker. Test by lightly pushing in on the outsides of the speaker to see if it moves in and out freely. If there is a scratching sound, or it drags slightly , it might be blown. Also,the dust cap or another part of the speaker may be loose. Check that, and reseal if loose. Replace or have reconed if blown.
Nov 02, 2014 | Mackie MR8 ACTIVE STUDIO MONITOR MR-8
Hum
You should check the earth connections to the cartridge, make certain they are tight and correct.
Dec 06, 2012 | Teac SL-A100 Turntable
Is it possible to hook up 2-6x9 and 2-12in.subs to the 7540a and still pack a nice punch
yes it is however the hookup for it requires something a bit unorthodox
you have 4 outputs (bridgeable)
channel 1 and 2 must be bridged (to lower the ohms) then connected to the 2 6X9 in Parallel..
this must then be set to the high pass frequency (eliminates bass)
lower all the settings as low as possible then turn them up slightly to increase volume to a level where its the hardest and clean sounding..lower volume after
this eliminates the bass and keeps the 6x9 pushing your mid range and high range frequency
now you have 2 channels remaining,, set 3 and 4 to low pass and connect each 12" to an individual channel. (this keeps the bass and ohms high so you will get a clean bass to match with mids and high's. Dont set or bridge for a low bass as it will jam out the 6x9 and your music will sound terrible.
so there u have a simple hookup that will work and keep you sounding clean. remember not to raise the volume on the 6X9 too much as you will blow them..
Mar 29, 2011 | Infinity 7540A Car Audio Amplifier
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
My subwoofer on my philips 5.1 speaker system is constantly generating lots of bass noise even on mute.
I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
Jul 07, 2009 | Audio Players & Recorders
Adcom GFA 5500 right channel emits horrible sound. Broken highs and no bass. Is is repairable by a semi amatuer?
Adcom makes a great amplifer! Usually broken highs and no bass means blown speaker. Try hooking it up to a completely different input source. Try different speakers also. If problem persists, check the fuse. Most will have a fuse on the back you can screw out. Some have two fuses (one for each channel) If this doesn't fix the problem it could be expensive to fix. Also, does this model ave the thermal protection light and if so, does it come on at all?
Jun 22, 2009 | Adcom GFA-5500 2-Channel Amplifier
Bass problem
You're getting some sort of capacitor discharge noise on your signal. There's no easy fix for that. It will have to be taken in for service.
Mar 16, 2008 | JVC RV-B90 Boombox
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
