Question about Toshiba TEC B-572 Printer
Is there an altenative to using Toshiba heads
We would like to replace print heads on Tec 572's and 472's but are aware the supply of these will be discontinued early next year . Is there an alternative printhead that could be fitted to the our printers
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Not to my knowledge
Posted on Jan 14, 2014
  • 300 Answers
SOURCE: tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
Posted on May 18, 2008
  • 300 Answers
I can only guess there must be a problem with a setting either within the printer or your pc. It's unlikely to be a hardware fault as the printer self tests ok.
I have repaired quite a few of these printers, but haven't had your problem. I can only suggest your compare the settings (baud rate etc)
Posted on May 19, 2008
SOURCE: TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Posted on Sep 10, 2008
SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Posted on Mar 21, 2009
SOURCE: TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Posted on Mar 26, 2009
Does anyone know how to rectify the TEC B-SX4 head temperature error? it's the correct version printhead for the model of MLB and the correct firmware, but problem still exists.
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
Oct 23, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
How do I perform a test print on a Tec B-572 printer?
I'm sorry for late answer.
Just turn it off, Hold feed button for 5 secs while you turn it on again
Jan 31, 2013 | Toshiba TEC B-572 Printer
How to change te print head?
Remove two srews (Visible from front top behind the film two square holes) replace head and adjust if necessary the position of the print head.
Apr 03, 2012 | Toshiba TEC B-472 Thermal Label Printer
Hi, I have a Toshiba TEC B-SV4 which I use in Thermal Transfer mode to print on ribbon. But when I start to print there is always a little bit of the image missing - about 5mm - at the start of the...
I have re-instaled my tec sv4 printer and it is not printing anymore. It seems that it doesn't recognize the fonts anymore. It prints only numbers (and doesn't stop)
Can anybody tell me how can I fix this problem?
Jan 24, 2011 | Toshiba B-SV4D Label Printer
TEC B-572 printer, labels off center.
Check the alignement of the media guide. and the alignement of the print head. + X adjust parameter
May 15, 2010 | Toshiba TEC B-572 Printer
How to adjust print head temperature on TEC B-452-HS12-QQ
it depends if you are working with driver, label software or escape commands. If you are working with escapes you can try with command AY, refer to the programming manual.
If you are working with Seagull driver you can adjust the print density in OPTIONS
Oct 28, 2008 | Toshiba TEC B-472 Thermal Label Printer
TEC B431-GS10 problem- Print-out in labels are only half
Various possibilities:
- The data cable on the head is not correctly inserted.
- the head is out of order.
- You are printing with a driver with a lower graphic resolution than the head resolution
Mar 31, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-572 Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
