Question about Drills
Had this for 3 months now the batteries wont keep a charge?
  • 237 Answers
Have to be careful... many chargers do NOT shut off automatically, and a great many professing to have automatic charge control - don't. Batteries can be ruined quickly by overcharging.
If you find this solution to be helpful, then please take a moment to rate it.
Posted on Jun 02, 2010
My camera is charged but it wont come on unless its pluged in,then it has a blue screen with MSDC on the screen. cant do anything with it.what can i do to get my photos into my computer?
You say it is charged but my guess is your battery has died. And needs replacing. If you do not keep charged up they will not keep their charge.. I may use my camera once a month but I keep the battery on my charger most of the time.
Jan 25, 2018 | Cameras
04 Avalanche 3rd battery in 6 to 8 months wont stay charged???
batteries will self discharge over a period of time especially in cold weather
however 3 batteries replaced in 6 months raises issues
first question is why would they not charge up on a charger or a run in the vehicle
second question is the battery of sufficient size to run the electronics
have you had the alternator bench tested to check for correct out put, regulator operation and rectifier problems
check drive belt condition and tension
the wire could be a ground wire but I would think that if it is significant then something would not be working correctly
Dec 29, 2015 | 2004 Chevrolet Avalanche
Battery drain
Have you checked alternator output on the van ?
Is the battery going dead overnight ?
Feb 19, 2014 | Cars & Trucks
Keeps restarting itself
Sadly, some batteries will wear-out within a certain amount of months, and some may go even greater lengths until they will require replacement. This is one thing many people may not know when they are charging their device: Devices that use internal rechargeable batteries also use extra memory to know the charge limit point. So if you charge your the battery the device must know when to stop so the battery wont over heat and be damaged. This memory used to charge your battery can also be confused and malfunction, so that the device wont get proper power supply from the battery. This malfunction will usually occur when you plug in your device and use it at the same time or if you charge your device at random moments instead of letting it get to it's lowest power point then charging it again. I suggest that you let the device die fully, then let it rest for a few days, then while you charge it, have it off instead of on, that way the charge wont interfere with the screen info and let it charge as long as it is said to take on the manual that came with the device. If this fails, try 2 more times,if no luck after, have the company change your battery, dont try to change it yourself if it's bulit in, because some batteries require soldering a similar technique to welding something together, you can do this your self if trained, but you may also void a warranty if you have one with the device. If you'd like anymore info on your device leave a message for us at Game-Shabang official on Facebook, thank you
Oct 25, 2013 | Audio Players & Recorders
I have a 1999 kia sephia and the battery will not keep charged, its a new battery and when i do get the battery charged the car wont turn over all the way
perhaps the engine is seized ?? so it will not turn over ,or the battery was duff one when bought it ,i have had three duff batteries from the auto factor in teh last month or so
Apr 25, 2011 | 1999 Kia Sephia
How to keep the motorcicle during the winter time?
take out battery and charge it once a month--drain gas or oil--dont let tires remain in one position-move um each month--maybe ride bike and u wont need to do them
Apr 11, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Wont start
Your battery is junk. Replace it.
Lead/acid batteries lose about 1% of their charge per day, so in 90 days of non-charging they are basically discharged. This is a bad thing. When winter comes, put a smart trickle charger on it, or at least once a month put a non-smart trickle charger on it for a couple hours or an afternoon so you keep it charged up.
I love/hate batteries.
Apr 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Battery not charging
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Jan 22, 2008 | Nokia 3110 Cellular Phone
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Drills Logo
35 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
