Question about Craftsman 3/8" Corded Drill
I have a Milwukee Drill - 1/2
I have a Milwukee Drill (not craftsman) - 1/2'' Chuck, it no longer works. The last job was demanding, and it started to smoke, but it still worked. Well, put it away, now trying it again. It no longer works. Can this be fixed?
  • 333 Answers
Http://www.ereplacementparts.com/
Sure it can be fixed. Here is a link that you can get a diagram and order parts. It is prob just the brushes.
Posted on Jun 02, 2010
What is the Chuck Taper Size? MasterForce model # 240-0064 12" Drill press
Masterforce is no longer supplier of power tools, they are a cheaper line of Makita, and maybe craftsman.
Jan 08, 2016 | Drills
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
My client has a drill press BDDP100 Type 1 - broken chuck
McMaster- Carr ships every where. www.mcmaster.com
There is probably a Grainger location in south Florida, they would ship any where you want.  www.grainger.com
There are a few different tapers used on drill chucks but they are pretty standardized: you don't need the black and decker part, you just need a standard chuck of the correct taper. try to get a basic Jacobs chuck they will last much longer than the one it came with.
Feb 28, 2010 | Black & Decker Drills
3/8 Drill Driver, chuck replacement.
hi friend,
Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
I Have a Craftsman Pro 1/2 in Hammer Drill . The Keyless Chuck is $50 plus ship and Hand. puts it over $70. Is there some type of off brand or can any replacement chuck work
Any replacement chuck will work as long as it is the right thread size and made for a hammer drill. I would try and find a JACOBS chuck for this. You should be able to pick it up locally.
Nov 12, 2009 | Craftsman Drills
Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Oct 07, 2009 | Craftsman Drills
CaN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
Jul 24, 2009 | Craftsman Drills
Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Feb 08, 2009 | Craftsman 4" Drill Press Vise, Side -...
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Craftsman 3/8" Corded Drill Logo
163 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
