My dell 5210 is telling me 929.000 and service toner sensor and will not print, any help?
  • sales519 Jun 02, 2010
    This did not help any other advice?
  • 6,487 Answers
Base from the description of your problem this is a clear sign of a bad toner sensor on your printer that needs to be replace to correct the problem that you have now with your printer So I strongly suggest you take this printer to service center near you and have the toner sensor replace to avoid further damage on it.
Posted on Jun 02, 2010
  • 4,924 Answers
Reset it ..look in the menu for teh reset feature and select to reset counter and that reset drum counter ..and navigate with the arrows and confirm ..
if this do not work ..try to open the front lid to get it in the service mode..and try again ...to see if it is any reset for the counters ..os ..try the clasic one with the power off unplug ...press the power button and keep pressed than insert the power cord..keep the button pressed for a few seconds than release For some models this is reseting the errors
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
Dell 1700 is giving me an error about the Toner. It also prints out a page telling me to replace the photoconductor kit. I have replaced the photoconductor and the toner but it still has the same error and...
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Apr 08, 2010 | Dell 1700n Laser Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
Help me pleaseI have a 1720 printer from a
Goto support.dell.com and follow the troubleshooter for "Service error 1720dn" that should narrow it WAY down for you. It's probably just the hsync is off on the laser. The troubleshooting trees that they have at dell will tell you exactly why it is not working correctly.
Aug 18, 2009 | Dell 1700 Laser Printer
Dell 1600n I replaced the toner and can't get the "replace toner"
After you clear out the print que (double click on the printer icon on your desktop), power down the printer, wait 20 seconds and power it back up. The "replace toner" should clear after the sensor detects toner in the hopper AND the new chip in the toner cartridge registers with the "brain" of the printer. Hope that helps!
Aug 12, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
5310n dell printer
Does it detect an old cartridge properly? Please verify this before disassembling. I've seen incompatible cartridges sent before. The service manual is the same for the 5210 http://support.dell.com/support/edocs/systems/prn5210/
Jun 26, 2008 | Dell 5310n Laser Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Minolta cf 2001
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
NO
NO
Clean or correct.
good contact.
YES
Dec 18, 2007 | Minolta CF2001 Copier
75 people viewed this question
k24674
jasbo
jasbo
