Question about Dryers
Rechargeable Camping Lantern
I have a 12v rechargeable camping lantern which now switches off after a few minutes operation. On letting it stand the unit works again after a few minutes only to cut out again, later on.
The lantern works off a rechargeable gel battery and powers a "four-finger" shaped flourescent globe. It has three LEDs to indicate battery level and charging status. Inside the unit is a PC board approximately 13cm x 6cm of electronic components. It's been working fine for the last 18 months.
I've ruled out the battery, (replaced and checked charge holding capacity) as well as the globe. A replacement globe also keep switching off.
Any ideas on what to look for please.
Thank you,
Paul
  • 85 Answers
You need to coldsolder the pc board.
Posted on May 13, 2008
Fluorescent lamp PL 9W 6500K (4pins) I ma looking for the fluorescent lamp for my Coleman rechargeable lantern
you can buy or order this from any store that sells coleman stuff... or online from coleman ...
Sep 05, 2017 | Coleman Camping, Backpacking & Hiking
Need to change battery in my 4345 lantern
If you are talking about the Coleman 4345 lantern it is rechargeable using one of the chargers (mains or car) stored in the base. Are you saying it won't recharge?
Mar 30, 2017 | Camping, Backpacking & Hiking
Hi- I have a Nexxtech LED Lantern that is no longer turning on.
Have you checked that the batteries are seated properly?
Sep 15, 2017 | Camping, Backpacking & Hiking
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
Should I use an electrical or propane lantern for camping?
I suggest propane or gas because they are cheap to operate and you are given the option of dimming, which is something you can't do with most electric lanterns.
Jul 09, 2012 | Camping, Backpacking & Hiking
I have a Vector VEC1378 rechargeable lantern - does this lantern also take a battery or must it be electrically charged only? If so, how do you open the battery case. Thank you.
I have the same and bought a $20 6v lead acid replacement from the Batteries Store. There are 4 small screws hidden under the foam rubber ring pad on the bottom. Very easy to open and swap out the battery. That said if you want to sell me your old lantern as is, I would enjoy having a second one for camping. Thanks and good luck. I can be reached at rudock1 at yahoo dot com. -Billy
Jul 25, 2011 | Vector Sport & Outdoor - Others
Dryers Logo
256 people viewed this question
Top Dryers Experts
