Question about Brother MFC-7220 All-In-One Laser Printer
Brother all-in-one printer not working; error 'back door open'
The 'back door' is not open, but the printer keeps scrolling this error. What is required to fix it?
    President:
  • 405 Answers
Open the front cover and remove the drum and toner.
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Posted on Jun 02, 2010
I keep getting a drum error on brother 7340, I have cleaned the corona wire and it still does not work
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Feb 11, 2011 | Brother HL-2170W Laser Printer
Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Brother MFC-440CN InkJet Printer
Back Door is open. Printer will not work. Keep
The black flap inside the rear door has a sensor flag mounted on it. The flag goes thru a hole on the side. If the spring is missing or broken or the flag is missing or broken, the error will persist.
Jan 06, 2010 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Back door wont close
First Isolate whether it is the Side Door or their is a door on the rear make sure that isn't open.
What I would do is Physically open and re-close all doors again the tabs and sensor get sticky after awhile. If not you could have a BAD sensor door switch.
Sep 14, 2009 | Brother MFC-7820N Printer
BROTHER HL-2040 PRINTER WON'T PRINT
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.
Apr 19, 2009 | Brother HL-2040 Laser Printer
Brother dcp-7020 printer shows error back door open.
open the front door then pull away your ink cartridge then clean dust or blur from ink cartridge position then refix ink cartridge again.
Mar 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
BACK COVER OPEN
thetre is a sewnsor in the back door, make sure it is in the right position
Jan 14, 2009 | Brother DCP 7010 Multifunction Laser...
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back cover open message
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Sep 02, 2008 | Brother MFC-7820N Printer
Brother MFC-7220 All-In-One Laser Printer Logo
402 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
