Question about Frigidaire FER641FS Electric Dryer
How do I get the back panel off, so that I can get to the fuses? The screws have been removed. It appears the back panel is either glued,welded or painted shut! My dryer is spining but there is no heat?
  • 619 Answers
Put all the screws back in the dryer where they go. The heater has probably dropped down and will be fun to resecure but it must be done. All service to your dryer is done through the front and you don't have to move dryer from wall at all. Use a flat bade scre driver or putty knife on the front left and right sides at top and the top pops up and there are the t-stats and all.
Posted on Jun 02, 2010
How to repair the lower intake flexible hose on the Hoover Agility
hoses are screwed into the end bits by turning in the do up direction
original equipment hoses are normally glued into the end piece but with a bit of determination and a flat bladed screw driver, the glue can be broken and the end removed
fit the good section of the hose into the end and screw it in using an un do direction
if it is the plastic fitting itself that is broken then weld the broken section back together
Basically use a soldering iron and heat the sections until the plastic melts back together
There are u tube pages that show how easy it is to do as they heat weld all sorts of plastic and tips on how to improve the strength of the repair. go google and type in how to weld plastic.
Apr 14, 2015 | Hoover F6212-900 / F6215-900 SteamVac...
Replace right rear quarterpanel
replacing a quarter panel is no easy task. it is spot welded all around the perimeter. To do it properly you will need to remove the rear window, the quarter glass, the trunk lid, rear panel, tail light, bumper cover, rear wheel, and inner wheel panel liner. every spot weld found will need to be cut, but only thru the outer panel. You do not want to cut all of the way thru both panels as you need to have something to attach the new panel to. After all welds are cut, there are welds under where the back window and quarter window go, and there are also welds in the sail panel that is between the quarter and rear windows where the quarter meets the roof panel. After all welds are cut and cleaned up you will want to cover all bare metal with a zinc based primer. You will want to drill holes all around the perimeter of the new panel and attach it to the vehicle with clamps or self tapping screws temporarily until you weld the new panel in place. You will want to fill in the holes you drilled in the new panel welding to the panel underneath. once all is attached you can remove the clamps or tap screws, if you used screws weld these holes as well, then grind everything smooth. finish up with a bit of body work especially at the sail panel where it meets the top, prime, sand, and now you might be ready for a trip to the paint shop.
Apr 21, 2013 | 2001 Toyota Corolla
How fix rear window off track on 2004 toyota highlander
The door pull has 2 screws inside.
the manual window crank has a screw in the center of the pivot.
the power window style has a few screws at the control switch assembly.
the door handle has 2 screws(10 mm) deep inside.
The rest of the panel comes off by gently prying at the edges of the panel with a putty knife. There are plastic"poppers" that hold the panel to the door.
Easily broken.
Use a flashlight to see where they are. Be careful.
Mar 09, 2013 | 2004 Toyota Highlander
Replace drive belt bosch classixx dryer
worked for white knight dryers for a while and saw that the siders and main case are spot weldetd together, but dryers are really simply put together, take out more parts so you can get to what you need, but take pictures to remind you how they go back
Feb 10, 2012 | Washing Machines
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
GGQ9800PW1 How can I remove the back panel? My dryer spins but does not heat. I've been advised by a reputable parts/replace place how to test the thermal fuse. They said to remove the back panel as if...
Newer models have access through the front lower panel. Removing the panel will expose the t-stats and all other parts. Remember to disconnect all power to dryer before servicing. Disconnect the wires to the thermal fuse and join them together. Connect dryer and start, if it heats up then your fuse is bad. Costs about 10 bucks.
Jun 30, 2009 | Whirlpool GGQ9800L Gas Dryer
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 cabinet seperation
go to www.dewaltservicenet.com
shearch by model DW911 loock the break bown
Feb 16, 2009 | Dewalt 18 Volt Compact Drill Kit
Can't remove back of Kenmore 66901
believe that model has lower front panel remove it ..clips each side top edge press them down pull panel off ..element ,fuses thermostat behind it
Nov 18, 2008 | Kenmore 62602 Electric Dryer
How to remove the back
Dryer back does not come off, the screws removed secure parts to the inside of the case.
put them back before anything detaches.
the front panel comes off
  • pull wall plug
  • remove lint screen
  • remove 2 screws in housing under lint screen
  • with putty knife or other blunt blade in gap between top and front,
    depress spring catches at both corners of top panel front, tilt up top
  • remove 1screw each side 1/3 down front panel
  • remove door swicth wires
  • tilt front panel down and remove
all internal parts are accessible
perform repair
examine rear of case from inside and refit anything detached by screw removal
reassemble in reverse order
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
Frigidaire FER641FS Electric Dryer Logo
69 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
