Question about Maytag MDB5100A Dishwasher
My dishwasher doesnt turn on no lights, nothing
  • 619 Answers
Appears the door switch has gone bad. More than likely the white neutral side of the switch is bad which will cause this.
Posted on Jun 02, 2010
MY DISHWASHER DOESNT START
Will need some description of the problem, in particular what actions you have taken, for example, door is closed and you start wash but nothing happens. Or you do not see any lights on the panel. etc.
Please provide model number and make of dishwasher as well.
Dec 04, 2012 | Dishwashers
Has power to it but doesnt turn on or do anything motor burnt up?
there is a thermal fuse located on the electronic control that generaly goes bad ( within the door panel)to prevent further function, power to unit, but nothing lights up, id check this fuse for continuity first!
May 17, 2010 | KitchenAid Dishwashers
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
The light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
May 31, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Sep 03, 2008 | Kenmore 16872 Built-in Dishwasher
Whirlpool dishwasher wont turn on, no lights, nothing.
It will be your door lock assembly
HERE are the drawings and parts of your machine
Jul 23, 2008 | Whirlpool 24 in. DU915PWP Built-in...
Dishwasher not working
dishwasher dwd 3410 w,it runs normal to the end but doesnt drain the water
Mar 25, 2008 | Beko 24 in. D3421F Free-standing...
Maytag MDB5100A Dishwasher Logo
88 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
