SOURCE: unlocking Nokia N93
Irfan, don't get penic. Sorry but there is no master code and no one can provide. Only the technician who have UFS_HWK, JAF, BB5 or any other compitable tool can do this for u, but offcourse with some normal charge. You can remove security code by formatting the phone but it will format your whole data also. The choice is yours. If found this helpful do vote here. Another Irfan (PATEL) here.
SOURCE: plz help me unlock my security code..Nokia 6288
hi, i can give you the master code but you need to read this first ok.
1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software.
2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone.
enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code.
Any problems just give me a shout back ok.
SOURCE: Forgot nokia n70 pin code
Get your phone IMEI number which is a fifteen digits number located in the battery compartment of your phone.
Then Visit http://www.nokiamastercode.com
Input the imei number at the site to generate a master reset code which you input when you switch on your phone.
This enables you to reset your phone security code.
Rate this fixya. Good luck.
SOURCE: orgot my security code Nokia 1100
Your IMEI: 359399009958078
Your Nokia Master Code: 6260611472
Steps to type Master Code:
1.This is master code.It has to be entered when your phone is started and asks for code..(security or master)..
2.If you type 5 times wrongly,the phone will get whole locked.. so,try 1 time.
3.If you fully typed 5 times wrongly ,you have to get a software tool to unlock and that costs greater than the phone you got..
so,try 1 time and let me know..
my email id:[email protected]
