Question about Linksys Wireless-N WRT150N Router
Linksys wrt150n power button blinks.
Why does linksys wrt150n power button blink? Using cablevision NJ motorola modem. internet has been spotty last 6 mionths and wondered if this blinking linksys power light was cause of repeated problems.
  • 561 Answers
Hi
Thank you for your query
This should be a solid light not a flashing light, and it highly likely the cause of your problems
I would suggest you try plugging it into a different socket to ensure it is not a faulty socket
Failing this you may need to purchase another adapter first in case that is faulty. They can be purchased cheaply from ebay
If this fals then your router itself is faulty and will need to be replaced
Regards
Shauqat
Posted on Jun 02, 2010
  • Linksys Master
  • 6,487 Answers
The blinking power on your router is a bad sign that it has some problem on it. You can follow the step by step procedure from my TIPS to fix that blinking power problem on your router.
http://www.fixya.com/support/r3801591-fix_blinking_power_light_linksys
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
We just got a road runner cable motem, and I had a linksys router before we got the road runner. I have a dsixl, and it's not connecting to the linksys anymore. please help.
Unplug the roadrunner cable modem completely as well as the Linksys. Let them sit for 20 minuets or so and then plug in the roadrunner modem first. Let it power up completely and then connect the linksys via the internet or wan port.
Check for connectivity.
If no internet connection enter the linksys control web page usually at 192.168.1.1 and perform a ip address release/renew on the status page.
If you do not know your admin login for linksys the default is admin with a password of admin. If you are unable to access the router then perform a factory reset on the router.
Make sure the router is powered ON. Then Press+Hold the Reset button of your router for 30secs first. (Reset is found on the back panel of your router, you have to use a pen or a paper clip to press the button) For the LED's if the power blinking that indicates that the router is being reset and then power-cycle the router for only 30secs.
If the Power LED won't blink Press+Hold the Reset Button for 1min and then Power-cycle the router for another 1min. Then check the IP address of your PC then try accessing your router's GUI admin console using a web browser with the address of 192.168.1.1 and use admin as your password.
Mar 13, 2011 | Linksys WRT120N Router
My linksys wrtp54g wont stop blinking. I have internet from the modem and when i connect the ethernet cable to the router it just blinks and I dont get any connection. I have tried the reset button......
hi
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Jul 04, 2010 | Linksys Wireless-G WRT54G Router
Linksys has stopped working - no connectivity. I directly connected the modem to computer and it works fine. Power light on Linksys is green but is blinking and does not go to steady green.
You can try to follow the steps from this link to fix the blinking power light of your router, because a blinking power light is a sign of something is bad on the router. But if after doing the steps and still a blinking power the router is already bad and needs replacement.
May 06, 2010 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
The Linksys WRT54G ver.6 worked until yesterday when I lost access to the internet. The "power" light is blinking continuously, so I went through the troubleshooting exercise of power off, power on - no...
Blinking power light usually indicates device being faulty. Was there a power surge? Try resetting the router by pushing the small reset button at the back with a pin for 10 seconds, then power it off and on. See what happens
Jul 05, 2009 | Linksys Wireless-G WRT54G Router
I have a linksys wrt150n wireless router
Do you see the wireless light blinking? IF yes then there are a few things you should try.
1. Factory reset. Press and hold the reset button for 10 seconds then reconfigure your router and see if it resolves the issue
2. Firmware update. Download the firmware update and then access you router and click on firmware update and browse for the update you have downloaded(you have to extract it first just in case its zipped) Hopefully that will do the trick.
If none of the these work then its a hardware fault and you will have to get your router serviced!
Sai.
Mar 01, 2009 | Linksys Wireless-N WRT150N Router
Reset password for linksys wireless-g router
Press and hold the reset button for 60 seconds, after you release the reset button wait until the power light stops blinking. If it does not stop blinking, then unplug it for 30 seconds and plug it back in. After that type in at the address bar, 192.168.1.1
Feb 08, 2009 | Arris SURFboard SB5101 Cable Modem
Online Light blinking
change the last four digit in the hfc mac
192.168.100.1
Sep 03, 2008 | Arris SURFboard SB4200 Modem
Setting up the BEFVP41 Router with a Cable Modem and a Dynamic IP Address
Connecting the Router and the Modem 1. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. 2. Shut down the computer, and unplug the power cables to both the router and the Broadband modem. 3. Disconnect the Ethernet cable from the computer and plug it into the Internet or WAN port of the router. 4. Take the Ethernet cable that came with the router (or any another available cable) and connect it to the computer. Then, take the other end of that same cable and connect it to Port 2 on the back of the router. 5. Plug in the Broadband modem's power cable and wait for all of its lights to stop blinking. 6. After the lights on the Broadband modem stop blinking, plug in the router's power cable. 7. Start up the computer. Obtaining the PC's MAC Address Windows 98SE/ME 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input winipcfg into the ?Open? field, then click on the OK button. 3. The ?IP Configuration? window should appear, select the Ethernet Adapter that the PC is using from the drop down list. 4. Make note of the ?Adapter Address? which is the MAC Address. Windows XP/2000 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input cmd into the ?Open? field, then click on the OK button. 3. When the ?MS DOS Prompt? appears, input ipconfig /all then click on the [Enter] key. 4. Make note of the ?Physical Address? of the Ethernet Adapter (normally ?Local Area Connection?). Accessing the Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Cloning the MAC Address The steps for configuring the MAC Address Cloning feature of a Linksys router vary depending on the firmware version the router is currently using. From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. From the ?Setup? page, click on the MAC Address Clone sub-tab. 2. In the ?MAC Clone? section, set the option to Enable. 3. Click on the Clone Your PC?s MAC button. Once this is done, the ?User Defined Entry? will show MAC Address of the Ethernet Adapter of the computer you are using. Verify this address with the ?Adapter Address? or ?Physical Address? observed in earlier steps. 4. Click on the Save Settings button. Then, click the Continue button if prompted. If the logo matches the image above ("Linksys"), follow these steps: 1. From the ?Setup? page, click on the Advanced tab. 2. When the ?Filters? page loads, click on the MAC Addr. Clone tab. 3. When the ?MAC Address Clone? page loads, enter the the ?Adapter Address? or ?Physical Address? that was observed in earlier steps. 4. Click on the Apply button. Then, click the Continue button if prompted. Power Cycling 1. Shut down the computer. 2. Unplug the router?s power cable. 3. Unplug the Broadband modem?s power cable. 4. Wait for 30 seconds. 5. Plug in the Broadband modem?s power cable and wait for its lights to stop blinking. 6. Plug in the router's power cable once the modem?s lights stop blinking. 7. Finally, start up the computer and test the Internet connection.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Linksys Wireless-N WRT150N Router Logo
2,454 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
