Question about Maytag M7D24E7A Air Conditioner
Fan motor My air condtioner is not blowing air like it should be. It feels cool but the air I think the blower is shot
  • 402 Answers
I may be that your filters or cooling coil is dirty too. Usually when a fan motor goes bad it simply doesn't run.
Posted on Jun 03, 2010
My heat kicks on, I can hear it and feel heat when placing hand on vents. However,Nothing blows out.
Blower is not running ? Or is ?if the blower fans not working check fuses or replace motor , if your heat cycles and your blower blows cool air , its likely a heater core issue
Nov 09, 2015 | 2007 Ford Freestyle Limited
Air conditioner stop blowing in 2002 Dodge Caravan can feel cool air and vents when traveling down highway with ac power on. Just won't blow out
There is as blower motor resistor which is part of what makes your fan blow. So your fan isnt blowing but everything else works right? Thats what I would look @ first.
Jul 24, 2010 | 2002 Dodge Caravan
The fan does not blow. The switch turns, AC button lights like it is getting power but there is no air moving. Can hold hand over the vent and feel cool/hot air but there is nothing behind it moving it. ...
fuse located lower leftside of dash, but i think you might have a bad blower motor, turn it no and try tapping on it if it starts then bad blower it is or test it for power and ground if it has power and ground then its the blower. good luck.
Oct 27, 2009 | 1993 Honda Accord
A/C and Heater will not blow air..
Blower motor resistor is most common ($20-$70) it controls the blower motor fan and speeds or fan relay fuse (usually under the hood) If it's not either then the blower itself is bad. You can pull the motor and apply 12volts to it to test, if it spins then the resistor.
Oct 02, 2009 | 2001 GMC Sierra Crew Cab
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
My a/c will not blow out air. You can feel the
Sounds like a blower motor not turning the blower. Could be elecrical. Check fuses that control the blower motor or blower motor relay. If these seem to be okay, locate the blower motor relay and try replacing it with a known working relay of the same style. If the A/C begins to blow, then you need a new relay. If not, you'll be looking into the blower motor or fan. Make sure your cooling fans function while your A/C is engaged.
Jul 03, 2009 | 2002 Buick LeSabre
Air Conditioner/Heater
Try setting the fan to medium, when you want less air blowing pull out on the ac button. Don't change fan setting.If your blower motor is starting to fail this will cause the motor to draw too much power blowing your fan fuse. If you want to get more life out of the motor do not set the fan switch above medium and it could last a lot longer. If you have the Extra money around $150.00 for the blower motor and at least that much again for the labor unless you DIY then you may choose to replace it I did this on My 91 Dodge B350 Xplorer Van Camper last august and it is still working.
Jun 18, 2009 | Sierra Online, Inc. You Don't Know Jack...
Motor fan blowing
do you keep the fresh air button on ? if you do , you will feel heat or cool air come in with out the blower motor running
Dec 01, 2008 | 2004 Chrysler Pacifica
Ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Jan 24, 2008 | GE Built-In Room Air Heat Cool Air...
Maytag M7D24E7A Air Conditioner Logo
64 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
