Question about E-Machines eMachines Desktop PC
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it connect ? It runs Vista by the way.
  • sbehanna1315 Jun 02, 2010
    Did all that. Nothing has corrected the problem.Have two other computers that work fine and connect to the internet on all connections. My emachines will not connect to ANY of them. Any more suggestions ?
  • sbehanna1315 Jun 03, 2010
    Did reset IP address. Did not work. :( Will try the other as last resort. Thanks.
    New Friend:
  • 65 Answers
Wireless is one thing but when your directly connected to your router with a cat 5 ethernet cord, you should be connected automatically. Since you checked device manager and it shows no indication with any device not being recognized then it is not a driver issue. When I plug in an ethernet cable I check to see if the light is flashing from behind the Tower. Then I would make sure the network connection with the local area connection (network adaptors) is not disabled. Right click "Local Area Connection" ,check the statis. It should display "IPV4" which will display from the right of that, internet or no internet. Sometimes Your DHCP might not have issued an IP address. Other problems that may cause a web page from not showing up is within the browser. Locate internet properties/ connections/LAN settings, sometimes I find the proxy server setting enabled which is (some cases) the problem to there whole disconnection. Must be disabled.
Posted on Sep 25, 2016
  • 217 Answers
First try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Posted on Jun 02, 2010
  • Griffin Keith Gonzales Jun 03, 2010
    hi!one more suggestion try to reset your ip address, if still does not work then probably last resort formatting your computer, if still does'nt then there might be a problem on your wireless card itself. goodluck!
Won't connect to router
Shut down compter, unplug router and the ISP modem, Check ALL cables and reseat ALL connections, plug in the ISP modem allow it to selftest, plug in the router allow it to selftest. Reboot the computer, plug in Ethernet cable.You didn't give much info to work with. Wired? Wireless? Does it connect to other devices? What is the OS? Vista? Is this a recent issue? What it the router Make ,Model? Open the Network and Sharing Center, Manage Network Connections, Is the Ethernet Adapter enabled?
Jan 07, 2013 | eMachines ET1161-03 PC Desktop
How do I get access to broadband. I have all the modems, ethernet cable links that work on another machine, but when I plug the ethernet cable in to my Emachine with a D845GVSR motherboard, I get no link...
if you need an ethernet driver or it might be something else
If you are trying to connect through a modem/router the ethernet driver should have come with a motherboard disc or the one supplied by your ISP internet service supplier
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps
Apr 07, 2011 | Intel D845GVSR Motherboard
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . :
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
Enter PING and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
I have an internet connection through my desktop that is plugged into a cable modem but when I run the Linksys Easy setup software it says it can't find a internet connection. I have turned off my Norton...
Make sure connections are correct. Cable modem to router with Ethernet cable. then connect router to computer with another Ethernet cable and see if it works.
o this:
1. hut down computer, modem and router.
2. put them on in this order waiting 1 minute between each.
---cable modem
you also have to check that the router is set up as dhcp
Dec 26, 2009 | Linksys WRT150N Wireless N Router -...
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
E-Machines eMachines Desktop PC Logo
1,570 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
