Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica bizhub 7272 imprint is too light
Copy machine was working fine untio we changed the toner. Now the imprint is barely visible. same problem with print and copy modes
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
First I would try fresh paper from an unopened ****. You could have moisture in the paper.
Some toners have a tape that has to be removed from the toner before installing into the machine. On the 7272 series machine there was a problem with the gears on the back of the developing unit wearing out and not adding toner. The machine would have made a loud grinding/gear skipping noise prior to failure. If this occurred the seals on the developer unit have gone bad leaking developer into the gears and ruining them. The developer and the developer unit will have to be replace.
Another possibility is the Transfer corona wire has broken or is dirty. Open the two front doors, lower the center lever and pull out the transport unit. A little the the left of center you will see some black paper guides, and under those guides are two channels. There should be two hair thin wires in one channel and one wire in the other channel. The single wire is the transfer wire. Make sure it is clean and not broken.
Posted on Jun 15, 2010
Bizhub 421 light copy result
Take out the toner cartridge and tap it on it's end to dislodge any packed up toner first. If this doesn't work and a new toner cartridge has no effect, then the high voltage applied to the drum is not attracting the toner powder. That will take a repair service to fix the printer.
Jun 10, 2015 | Konica Minolta Bizhub 421 Mfp...
KONICA 7272 CODE SC49-01
Image processing board failure. I would first check all the connection on the image processing board pull each connector one at the time and check for a bent pin, worse case the image processing board is bad, doubt you can find one a Legacy Konica Machine Konica is now KonicaMinolta.
Jan 21, 2015 | Konica Office Equipment & Supplies
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
May 13, 2014 | Konica Minolta bizhub C250 All-In-One...
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
Sc 21-05 for konica minolta 7272
The transfer and separation corona cleaning system locks, lubricate or replace corona unit
Jan 11, 2013 | Konica Minolta Bizhub 7272 Image Control...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
452 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
