Question about Kenmore 400 6942 Dryer
Kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check this picture which will sort out everything for you:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Will not come on,,checked door switch checked plug in breakers back is off,,,cannot read through little plastic fuse read on every thing else new unit heat coil pack is all new this is new unit
Posted on Jun 01, 2011
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore 400 series electric dryer
Are you wanting to do this because of your plugs at your house? If so, just go to Radio Shack or Home Depot and buy a adapter, a lot safer then doing the switch
Posted on Feb 08, 2009
Changing 4 prong plug to 3 prong plug on a Kenmore ultra fabric care electric dryer, where is the metal strap?
The metal strap connects the neutral to the housing ground connection when using a 3-prong cord. It may have been removed when the 4-prong cord was installed.
Feb 17, 2017 | Kenmore Dryers
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Have a kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what? Can we wire our 3 prong plug from the other dryer to the four wire dryer? And how would we wire this way...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Kenmore 400 6942 Dryer
How do I wire a 3 prong plug on a kenmore 400 series dryer
Jun 22, 2010 | Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer cord change
if you have the new plug the wiring is the same just without the green wire....just leave it off
Jun 24, 2008 | Kenmore 84832 Electric Dryer
Kenmore 400 6942 Dryer Logo
1,580 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
