Question about RIM BlackBerry 8700g Smartphone
Phone cuts out in the middle of the conversation or upon hang up. i reload battery and everything starts back up. do i need a new battery or is there a setting messed up.
  • 76 Answers
Reload OS with application Loader
Posted on Jun 06, 2010
My nokia n8 is a day old it cuts out after a few minutes into the conversation and says insert sim and phone will restart, why does it do this? and is there a way to fix it. Thanks in advance
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
BEING A NEW PHONE PLEASE SEEK FREE WARRANTY SERVICE AND DO NOT TAMPER.
Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Thank You for using Fixya
Aug 11, 2011 | Computers & Internet
It does not start properly. In middle it hangs
Open back cover, put off the battery, put in again, restart the phone.
Jan 23, 2011 | Samsung S3600 Cell Phone
Hi,everyone! I've been using Samsung D-820 for a long time but suddenly in the middle of a conversation,my display wont work anymore while everything else is working fine.Is that related with flat cable or...
yes surely its the flat cable or commonly called flex cable or ribbon connector is already have a cut or damage bring it to samsung it is the of your phone.
Oct 13, 2010 | Samsung SGH-D820 Cellular Phone
Phone goes dead
problem can be solved.Did you download any application from the internet?.If yes, that means the phone memory is dead and it needs to be flashed to restore the memory of the phone back.
You can also check for the battery may be it is not well charged because the cell of the battery might be weak and needs to wake up by much charger.
You can also get another battery to test the phone to be sure it is not the battery.
You can check both the battery and the board to be sure of wish is faulty.
Take care.
May 19, 2010 | Motorola Mobility RAZR V3
My uniden cordless phone CXA15198- is cutting off in the middle of conversations
My Uniden phone system CXA15198 -one base phone and one cordless was cutting off the conversation. I unplugged the phones for about an hour and since then they've worked fine. Next time it happans I'll get a new battery for the cordless phone.
Dec 27, 2009 | Uniden Lands Phones
Camera not working
My sister's blackberry curve 8310 had the same problem with the camera, it would just show up the "could not start the camera. Close other applications and try opening the camera again." message.
In my case the camera hardware was working fine, it just needed more pressure towards the motherboard so it would make more contact. I disassembled the blackberry completely. Then i used some extra foam i had from previous housings, like the one that some blackberries have in their battery cover to do a little bit more pressure on the battery or the one thats around the camera, flash and speaker. I took that foam and cut it into very small pieces and put it around the camera base in the motherboard and around the camera hole in the middle frame. Assembled everything and put some extra foam between the battery cover and the middle frame close around the camera so it would apply pressure. This will void your warranty tho, so yep its easier to just make a backup with desktopmanager and get a new one using your warranty.
Jun 02, 2008 | RIM BlackBerry Curve 8310 Smartphone
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Does not cut on
A free Tracfone? Have you tried a restart. Open the phone back, take out the battery, leave it out for 30 seconds, then reload the battery, try again.
I would call tracfone. Be firm and patient. If it is a bad phone, they should send you a replacement and help you transfer minutes. Do you remember how many minutes you have. in the phone. Be patient but firm -- and if the person on the phone does not seem helpful, politely say goodbye, Hang up and call again.,
Fred
Dec 05, 2007 | Kyocera Switchback KX21 Cellular Phone
Phone suddenly turned off...
You need an expert one to open your phone, during your conversation the signal components is in heavy duty, one of this is the signal power amplifier ( P.A ) the source of power is from power IC ( UEM ) grounded P.A sometimes kills the phone and need to replace it, if not work, the UEM is already busted replaced it, before all of this try to reformat first.
May 14, 2007 | Nokia 6600
RIM BlackBerry 8700g Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
