Question about Cuisinart CPT-70 Classic Style 2-Slice Toaster
I can't figure out how it goes back together. The toaster lever wasn't working, so my wife took out the crumb tray and turned the toster upside down thing something was jammed. A long metal rod and long spring came out. I got the chrome cover off, but now I can't figure out how the toaster lever and other parts fit back together, and I still don't know where the long rod and spring came from.
    Guru:
  • 351 Answers
That long rod and spring sound like the rod that the opperating lever rides on, kind of a guide, the spring is what pops it up when the toast is done .. should be sitting verticle in a groove or hole in the opperating lever.
Posted on Jun 02, 2010
Testimonial: "Thanks for your input. "
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Kitchen aid toaster won't stay down, heats when held down, but only on bagel setting. Checked crumb tray but all clean. What to do?
Contacts may be coated with Burt oil, butter, other matter. When engaged, contacts aren't engaging.
Aug 31, 2014 | Kitchen Appliances - Others
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
Toaster control lever will not stay down
Unplug the toaster, turn upside down, and gently shake all crumbs out. There's been plenty of times when a stray raisin causes this problem!
Otherwise there may be a break in the element. In Australia toasters won't stay down unless the power is connected, and if there is a break in the element there won't be a continuous circuit.
Nov 26, 2009 | Black & Decker Kitchen Appliances - Others
I have a pink two slicer kitchen aide Toaster. The button to pull down the bread to toast will not stay on. Where can I order/buy a new pink one? thanks kathie
Before tossing out the toaster, check on the inside of the toaster, you may have a wire bread closure in there that is blocking the lever.
I took my son's toaster apart when they replaced it, and found a bread closure inside it, blocking the lever. Anything small enough to fall inside could do this too. (The toaster works fine now, and I use it myself!)
Make sure you unplug the toaster first, you don't want to have a "shocking" experience.
Turn the toaster upside down and shake it a few times, over the kitchen sink, and then open and clean the "crumb" compartment.
Sorry to tell you this, but, your toaster is no longer available on the market, you might want to check a few thrift shops in your area...or you can check this link for another model that is pink and a KitchenAid.
http://www99.shopping.com/xPP-toasters--kitchenaid~S-213~OR-0
Oct 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Mar 27, 2007 | Krups 288 SensoToast Compact 2-Slice...
Cuisinart CPT-70 Classic Style 2-Slice Toaster Logo
273 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
