Question about Panasonic CQ-C1100U CD Player
Stereo Sound Hi there, my partner was driving my car and must have touched a button on the stereo as the sound now sounds quite "tinny" amd when I turn the music up the whole car seems to vibrate. I just want to be able to hear a clear sound inside the car without the car shaking!
    Novelist:
  • 100 Answers
You could start by adjusting the Treble and Bass. The treble is what makes the high notes more nodicable, so if you turn the Treble up you should be able to hear more vocals. The Bass is what makes the low notes more nodicable, so if you turn the bass down you should be able to stop the shaking which I'm guessing is the low notes. On the other hand if you have an aftermarket radio then there might be a Mute or ATT button. Theses are for instant quiet, just repress the Mute or ATT button and it should be fine. I hope I could help.
-Andrew Hawkins
Posted on Apr 09, 2008
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
2002 trailblazer. Factory radio sounds very tinny. Every once in a while it will sound normal, then reverts back to same tinny sound
may be a ground problem and may be in stereo itself. more than likely just a ground but still just a guess..good luck
Aug 12, 2012 | Cars & Trucks
Sound went out in the stereo i was driving and the sound went out in my stock stereo in my 2007 cobalt. the fuses are ok, the stereo light is on. theres just no sound. what can i do?
You might want to check and see if you have somehow lost connection to your speakers. Not familiar with vehicle but I do know stereo's, if the light is on on the Stereo then it should be OK. Check under the dash and around and see if something has come loose going to your speakers. Caution~ DO NOT try to touch another speaker to an existing speaker because if not done properly it will change the speaker resistance and result in a burnt out channel in your stereo.
Gillight
Jul 22, 2012 | Cars & Trucks
Converting vinyl lp's to cd's with same quality sound. When we use our turntable played through the stereo connected to our iMac and use Audacity, the resulted cd sounds tinny compared to the vinyl...
Hi, use acoustica spin it again. You can adjust the input levels and it will convert the records analogue signal to wave format. Cheers styluscity@gmail.com
Aug 21, 2010 | Audio Players & Recorders
No Stereo from Scoop
It is NOT stereo bluetooth compatible (A2DP)
You would need an adapter made specifically do come from an LG headphone port to plug into a radio.
The reason being because the Scoop's port has more contact points than a standard stereo port because it also uses the microphone on the same wire. The adapter you have is not compatible if you are only hearing one audio channel (left - right).
Hope this helps,
Simon.
Nov 17, 2008 | LG VX8300 Cellular Phone
Sony's car stereos, mine the
never mind, I'll ask a friend.
Jun 22, 2008 | Car Audio & Video
My stereo I had hook ed to my pc and it was working great then it just quit no sound at all..now after I unhooked the stereo I still cant get sound from my speakers
you might of overloaded your sound card , take it out turn your computer on .turn it off again reconect your sound card and try using your sound.your computer needs to reset the sound devices.Remember your soundcard isnt like amps found in souped up cars,
Jan 19, 2008 | Computers & Internet
Only tinny sound coming from the speaker MS904
The "tiny sound" may be a blown woofer you are only getting sound from your high section.
Dec 23, 2007 | Mordaunt Short 502THX Main / Stereo...
Panasonic CQ-C1100U CD Player Logo
159 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
