Question about Dehumidifiers
MY DENUMIDIFIER IS OVERHEATING. IS THIS DANGEROUS?
    Problem Solver:
  • 3 Answers
Yes, unplug it, and check the filter and coils to see if they need cleaned. Anything else, call a repair person.
Posted on Jun 02, 2010
Why does it keep blowing fuses and in there a warraty
any appliance thats blowing fuses is dangerous and should not be used in te home , hey if it more than three years old a new one will save you money in lower electric , before you pitch the old one ck with your power company sometimes they offer rebates for appliance upgrades !!!! and they require the old one for those to occur
Oct 09, 2014 | Dehumidifiers
Goldstar dehumidifier dh404ey7 starts and runs about 5 mins., then trips house breaker in all different outlets.
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Oct 02, 2014 | Goldstar Dehumidifiers
Dehumidifier repair
If nothing at all works, its most likely a control (switch or stat). Be very careful if you try jumping them. Line voltage is dangerous if your not sure of what your doing.
Oct 15, 2013 | Dehumidifiers
I just purchased a DE65EKL Model denumidifier. i hooked up the hoes connection but the bucket fills up instead. Why does the hose not drain water?
If the hose is longer than 5 feet, that's part of the problem. The hose must slope down and straight to a floor drain. It relies on gravity to drain.
Although you just purchased it, the hose connector and inner tubing may be clogged. This is another reason water is diverted to the bucket. Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector and tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow. It may take 5 to 10 minutes for water to appear.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you to troubleshoot & solves the problem. Thanks for choosing FixYa.
Aug 16, 2011 | Haier HD656E Dehumidifier
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
Compressor seems to be overheating although top is cool. Continues to run but doesn't collect water. Fan is working. Can't locate model number.
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
May 22, 2011 | Kenmore 54501 Dehumidifier
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
From Day 1 this dehumidifier, after running for a couple of minutes it gives off a very loud buzzing sound - not at all the typical motor sound. What is this and how do I fix it? Is it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It is not dangerous, but it also is not working...the sound is the compressor trying to start and not getting started... so the machine is basically toast... would cost more to fix then it is worth...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 14, 2010 | LG LHD659EBL Dehumidifier
Amcor dehumidifier motor running very slowly
Hello Filter neglect is a popular cause of problems.20yrs you got your moneys worth the unit dosent owe you a thing.Burning smells sounds dangerous.Please look into replacement.
Mar 31, 2010 | Dehumidifiers
My dehumidifier is making a power surge every few minutes. why?
A dehumidifier is functionally the same as an air conditioner. It has a compressor motor, which is a fairly high current draw item.
First of all, unless you are well versed in electrical repairs, you should unplug this unit and do not use it. This is a dangerous condition and a fire or electrocution could result.
One of four things is happening:
1) You have a wiring fault in the circuit your humidifier is plugged into. There is a loose connection in the circuit, causing a voltage drop, and the humidifier therefore has to pull much more current to start it's compressor. This is a very dangerous condition, as an electrical fire could result. Try plugging the unit into another circuit and see if it does the same thing.
2) the compressor of the humidifier is going bad and is shorting out internally. Time for a new unit.
3) Many compressor motors use a 'start capacitor' to help the motor get going. If this part has failed, the motor will try to start, but it will not be able to.
4) There is a fault in the power cord or controls of the humidifier. Just like #1 above, a loose connection could cause a voltage drop, making the unit draw high current.
most of these units are standard 110V units. If yours uses 220V (like an electric dryer), then it could have 'lost a phase' which is also a similar electrical issue.
Oct 16, 2009 | Dehumidifiers
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
