Question about Whirlpool LGR5644J Gas Dryer
Heat won;t turn on
I have a Whirlpool Accudry gas dryer (not sure of model number; it is between 5-10 years old) and i have never had a problem with it. I have power to it, because it turns on and runs, but no heat is generated - just cold air. I get the vents serviced every 12-18 months, so I know it is not clogged with stuff. Help!
    President:
  • 1,430 Answers
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Jun 02, 2010
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
Whirlpool Gas Accudry dryer has no heat...everything else seems fine.?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Aug 11, 2011 | Dryers
Whirlpool AccuDry Ultimate Care II Dryer will heat up
heatman101
Jul 17, 2011 | Dryers
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
My dryer wont heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will turn but won't heat.
Check the gas valve in the back of the unit and also check the Glow ignitor to make sure that you are igniting the gas to heat the drum. Sounds more like it is the Glow ignitor that is bad
Feb 09, 2009 | Whirlpool LEB6200 Electric Dryer
Open Questions:
Whirlpool LGR5644J Gas Dryer Logo
244 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
