Question about Runco CL-510LT Multimedia Projector
Unit not powering up. New lamp installed but
Runco cL 510 unit not powering up. New lamp installed but problem remains. Was working perfectly before.
Thanks
Don
  • 75 Answers
A couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Posted on Jun 06, 2010
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
I have no power to my runco cl-710 projector.... no lights will come on regardless of the power cord I use. I have made sure the lamp cover is on securely and correct. any ideas?
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. This is an easy repair.
Jul 18, 2011 | Runco Office Equipment & Supplies
I bought a new Cannon PIXMA MX320 with no ink cartridge, the manual says that it requires PG-210 & CL-211, while the cannon site says it works with the PG-510 and CL-511. so my question is do they both...
Cannon cartidge numbers are quite confusing to say the least, but your printer requires PG-510 and CL-511, PG is black and CL colour.
The 210/211 is a non european number, but they are the same as CL-511 and PG-510.
Hope this helps.
Jul 01, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Reset lamp timer runco vx-5000
Using the remote control for your projector, turn the unit on, then select 'menu' on the remote. On the menu that pops up in the screen, select 'SERVICE', then 'DISPLAY DEVICE', then 'INSTALLATION'... once you select that, scroll over to the "RESET" under the lamp hours... this should reset it.
Here is a link to the owners manual for your unit.
http://runco.com/legacy_prods/legacy_manuals/VX4000d_5000d_manual-v3-1.pdf
Nov 01, 2008 | Runco VX-5000ci Multimedia Projector
Need to adjust from full screen to wide screen on Runco SC3050
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Oct 11, 2008 | Runco CL-510LT Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Open Questions:
Runco CL-510LT Multimedia Projector Logo
612 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
