Question about Samsung HLP4663W 46" Rear Projection HDTV
Dlp replacement lamp just now installed, but TV still won't work and (3) LED lights still blinking. Any ideas ?
  • 88 Answers
Be sure the lamp cover door is closed to activate the safety switch. Otherwise the set will need a ballast or possibly the color wheel is not starting........it can be defective,especially if you have heard a whining noise prior to the set failing
Posted on Jun 02, 2010
How do you know if your lamp is out. there is still light on in the back of the tv
An LED indicator on the front panel of your TV will blink even you have light in the back panel of your TV this LED indicator will remind you if the lamp must be replace because DLP projection has a lamp hour meter the lamp time for this DLP 6000 to 8000 hours.
Sep 23, 2011 | Mitsubishi WD-62526 Projection TV
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
I can hear the movie but do not get a picture but the lamp light is blinking
Ur tv Projection lamp is dead.Ur tv Projection lamp,require replacing.The "LAMP"LED light indication blinking flashes or stay on.The projection lamp must be replaced,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a new projection lamp.
Aug 04, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid...
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
157 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
