What things can i buy to make my own laptop water cooler?
  • Robin ray Derro
    Robin ray Derro Jun 03, 2010
    please put you solution step by step.. thank you
  • 11,800 Answers
You can't put a water cooler on a laptop, there isn't enough space inside.
If you still wanna do it you will gonna have to cut a big chunk from the case to install the cooler and the pipes and to attach the pump and the radiator to what's left of the case you will have to glue/screw in some brackets.
BTW that Frankenstein's monster would stop being a laptop since it would stop being mobile.
Posted on Jun 03, 2010
  • Azrael SRL Jun 03, 2010
    1. You buy a water cooler for desktop - find one in which the pipes don't do perpendicular on the cooler.
    2. Remove the back of the case, remove the original cooler (held on the motherboard with screws and springs)  and make sure the other cooler from the chipset is still firmly attached; put the new cooler -  you will gonna have to modify it to attach it - and attach the water pipes to it.
    3. Cut from the back case whatever is needed to close it back properly. Glue some feet to its 4 corners as to allow the water pipes to go easily to the cooler. Glue next to the feets some brackets - you will attach the pump and the radiator to them (make the brackets yourself, they aren't sold anywhere).
    5. draw some power wires from the battery to a switch and then to the pump.
    6. fill with water and enjoy. If you move it or do anything that will allow the water to leak, or you will simply forget to start the cooler before starting the laptop - it will fry instantly.
    Don't do it - if you have the money to buy a gaming laptop then you have the money to build a much more powerful desktop.
Want to make my fan quieter
This is not something you want to mess with ..cause the fan is crucial for the safety and function of the laptop ..The fact that its loud it indicate the cpu is used excessively ..and its temperature rises to the limit . If you want ..you can open it up ..and install a better cooler for it ..or if it has the space ..and you see on the internet a upgrade for the cooler ..you can buy it and install it ..This will not make it silent for good..but a better heat dispenser will dispense the heat more efficient and he cooler will have no need to kick in and make all that excessive noise..
Another thing you can do for to protect and avoid the noise ..is to buy a external heat dispenser..-cooler ..and use it..These are some kinda frames with a extra cooler and your laptop will fit into it ..and the cooling will be permanent so it will not sense the need to start the internal cooler at the max speed.
Just look over the net and take a look for some models ..
another thing ...if you want to upgrade the heat dispenser ..make sure it will fit for your model ..(the hit dispenser (internal ) it is a aluminum piece in which the fan is located..and have the function to get the heat from the cpu itself ....its job done better ..will basically reduce the cooler intervention but in excessive use..
Nov 29, 2011 | Acer Aspire 5315 Notebook
Need to find thermostat for hot water tank for hamilton beach water cooler
Is this model 87307? I want to buy this model. My e-mail is vmd011@hotmail.com
Nov 04, 2010 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
Aug 18, 2009 | HP Compaq nx6110 PC Laptop
My hot water on model #87330 cooler has stopped working the switch is turned on in the back
Unfortunatly this is going to be a bad heating element or high limit thermostat, It's going to be cheaper to buy a new one or just make do with cold water. Sorry I can't be more helpfull but i worked on these things for a while and the company i worked for would rather buy new then put time effort and parts into a $100 water dispencer.
if I can be of any more assitance please feel free to comment again.
Jun 23, 2009 | Hamilton Beach Water Cooler with Storage...
Cold water is freezing
if ur water cooler is freezing there could be two different things wrong, one yes is the thermostat, the second how ever is a relay switch located at the bottom of your cooler.
need any help? omilian.jos@gmail.com
May 04, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water coller
hello chattie wm,
Welcome
You said, the hot water side stop working,no hot water
This is usually one of five things.
  1. Check that the power is on at the breaker and the cooler has the proper light lit up that shows you it is on.
  2. If you have had it a while, (year or more) it may be that the heating element is covered
with minerals from the water which if it's hard water can happen too!
3.The heating element may be bad and need to be replaced.
4.The thermostat may be bad.
a.How old is it ?
b. What did it cost to buy?
You do not want to spend more than half what you payed for it to repair it!
Let me know how it goes and what you decide.
Thank you for using fixya,
Huum....Please remember to leave a rating!
Oct 14, 2008 | Hamilton Beach Water Cooler with Storage...
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
