Question about Hotpoint Aquarius WMA42 Front Load Washer
Washer fills up then goes straight to fast spin
Whats a tacho
4 Suggested Answers
  • 54 Answers
SOURCE: hotpoint wm65
check the back of the motor to see if the tacho's loose
Posted on Feb 14, 2008
ginko
  • 19396 Answers
SOURCE: GE front load washer (clothes)
Check the drain hose, probably it is not spinning because the drain pump is faulty.
Do you get any error code?
Posted on Sep 07, 2008
marka19
  • 1430 Answers
SOURCE: water comes in and goes straight out
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available. If you need help with accessing try this link http://appliancehelponline.com/toploadcabinet.html
Posted on Jul 13, 2010
Beko washing machine seems to go straight into a spin cycle,bangs around too.I did the test program, it didn't turn clockwise gently or anticlockwise gently it just spun really fast then blew the fuse
Hello!
It sounds like the triac, which drives the motor is in short, you can recognize from the heatsink, on Beko usually is riveted, not fixed with screw, but you can drill'em off, its an BTB12 ( or 16 ) Triac, replace, thermal grease under and back.
Rarely this problem could be caused by tacho circuit error, but ususally Beko just stops and do nothing when tacho error
Aug 31, 2016 | Beko Washing Machines
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Wa50t54w1 elba
this can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
Oct 24, 2013 | Fisher and Paykel IWL12 Top Load Washer
Hi i have WMA5 and when i put it on any cycle it goes to spin then straight away goes to program end what could this be and can u help me?thanks tim
Hi Tim. Sounds like the tacho wire has come off or broken. For a quick check tilt the machine back and look underneath check out the white wires from the motor to the front of the machine you may see a definite break in one of them. Dont attempt to repair it from there you will need to remove the front of the machine to affect a repair, if there are no visable signs you will need to do an electrical test on the wires. for WMA repair manuals check out www.selfix-uk.co.uk
Apr 14, 2011 | Hotpoint WMA50 Front Load Washer
WIDL126 flashing light No3 extra rinse). Machine starts to fill with water then the drum spins twice (a little too fast I think), then drains and just stops and the door lock light flashes fast along with...
If spin speed happening during what should be Wash speed then sounds like faulty speed control module/ could also be Tacho has fallen off end of motor;small round coil operated by a magnet which pulses a speed control circuit in the module/check also pump is okay and filter clean.Try resetting if you can,book will show you how to..Good luck
Apr 07, 2011 | Indesit Washing Machines
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Error code E52 can't find manuel doesn't spin fast
bad signal from tacho generator. You have to disconnect the plug from the drive motor and measure the resistance pins 4&5 in the motor. if the reading is between 105 & 130 ohms, replace the speed control board. if the meter reads other than between 105&130 ohms replace the motor.
Oct 20, 2009 | Frigidaire ATF6000ES Front Load Washer
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Hotpoint wm65
Dec 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Fills, washes, but won't drain or spin
Possible your outlet filter is blocked, it needs periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first.
Jun 13, 2007 | GE WWSE5200B Top Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
19 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
