Question about HP Pavilion HDX9000 Notebook
DVD rom can't read some factory made disks and none of the burnt disks, can't write any disks. No sound from main speakers (only with headphones) QuickPlay buttons doesn't work. Tried everything recommanded on web so far with no luck. Ordered Recovery Disks from HP to restore to factory condition and I'm ending up with recover7.exe error. Please help~~~
    Novelist:
  • 83 Answers
Hi, For DVD ROM try to use another working CD on the same DVD rom if they are working then CD are not working but if those CD/DVDs are working on another computer then it is DVD drive issue. It needs to be changed. First check the ODD is getting detected in device manager or not. Also try removing upper filter and lower filter from registry. Use below link to know the steps and then check. Microsoft Fix it. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00678214 For Internal Speaker- If sound is coming from headphone and not from the internal speaker try these steps. 1. Click Start > Control Panel , and then click Hardware and Sound . 2. Click Sound and then select Speakers and Dual Headphones . 3. Click Set Default and then click OK . If still not working then sound board which is on the motherboard is not working. Then it?s a purely hardware issue and you need to replace the motherboard. I hope this will be helpful.
Posted on Jun 02, 2010
  • 192 Answers
Two possible scenarios have occurred here. I believe both have to do with your motherboard. Since your problem is intermittent and teh system WILL BOOT..it sounds like the soldering on the board has come loose at a connection point. The most common cause of this is picking up laptop by corner and an item called FLEXING. this is when the laptop bends under its own weight and this can either damage or destroy a motherboard. Ive seen lots of people pick up laptops from one corner and this occur. Since these Motherboards require MICRO soldering its not a fixable problem by your local home repair soldering gun... I would recommend a local repair shop for computers and let them reset the CMOS and try and reload a BIOS and start from scratch. If you have data on the hard drive you dont have backed up it is lost at this point due to recovery effort. The average cost for a diagnosis of the issue will be about $85... if they can Microsolder then expect about $200 IF THE PROBLEM CAN BE FOUND.. Lots of solder points. Two other things to google woudl be HP and NVIDIA problem (some graphics cards from NVIDIA are bad and cause laptop failure and are documented on google) Also check MAX1987 Heat chip issue... this is a soldering issue too..but may be part of the issue.
Marantz SR 3001 won't turn on
Check for shorted speaker wires - if none found, disconnect speaker / select headphones and see if you hear music thru the headphones. If not - you may have burnt out power transistors, etc.
Jan 12, 2014 | Marantz SR3001
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
I want to install Wnidows XP is it possible
ya its possible find the xp minimum requirement.
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600)or higher resolution
  • Sound card
  • Speakers or headphones
Dec 03, 2009 | Toshiba (4CH-VOUT) Sound Card
Cd/dvd not recognising anything
check if you have connected the dvd/rom according to the specifications entered. if no then do it and check again if the player reads the disk. if the problem persists, and i you suspect its the manufacturer's error, then you can get a free replacement according to the warranty details
Jun 06, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Samsung SH-S202J won't read blank disk
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 13, 2009 | Computers & Internet
IS-PDVD10
Check the headphone ports to make sure the port is functioning.
Insert and remove a headphone plug into the headphone jacks to mkake sure the headphone jack isn't stuck and cutting off the audio tot he speakers.
If you have no audio from the speakers or from the headphones, open the setup menu and navigate to SOUND or AUDIO and make sure you are set to PCM audio and not RAW.
If none of these solutions help, you have a problem with the player that is electrical and not easily repaired.
Jun 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Pioneer DVR-109 DVD±RW...
This ahs to with speed of recording of the CD/DVD try reading CD/DVD burnt at a lower speed like 16x.
Most DVD writers has low maximum reading speed as compared to CD-ROMs.
You can try burning a CD on it and then reading it, if reads then it shows that other cd were burnt at faster speed than it can read.
If it read lower speed CDs then you can just add an additional DVD/CD-ROM just to read faster speed disks.
Mar 24, 2008 | Pioneer DVR-109 (44121479) DVD±RW...
Will not read a disc
First of do one thing u should have chek your dvd rom detected or not in bios. if it is detected then chek another disk in to dvd rom after these same problem persist you should have to replace your dvd rom.
Thanks
Dec 28, 2007 | Acer Aspire E380-UD420A (ASE380-UD420A)...
WINDOWS XP
Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
Aug 29, 2007 | Computers & Internet
HP Pavilion HDX9000 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
