Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Middle spray arm clogged
Items in upper tray do not get clean because middle spray arm is partly clogged, probably with mineral deposits. The arm appears to have two parts which could be separated for thorough cleaning. Can this unit be disassembled for cleaning and reassembled? If so, how does one do this?
  • 56 Answers
No it cant to clean a dishwasher good the best thing you can do is run lemeshine often found at a publix or wallmart in the dishwasher detergant isles . if you try to sepperate the arms ther is a very good chance you will break the water tight seal and it cannot be fixed without replacement.
Posted on Jun 02, 2010
Can the beko spray arm be taken a part to clean inside
spray arms should be easy to remove, but not sure whether they can be taken apart. if they are clogged with hard water deposits, you can prevent it from happening again by replacing some of your detergent with with an additive. www.CloudyDishes.com
Sep 03, 2014 | Beko Dishwashers
Dishes do not look clean . does not spray well
Sounds like mineral deposits are beginning to clog up the spray arms.
Ya might check into local hardware store to get an additive.
Possibly something acid based like vinegar would help...
Hope this helps a little...
Jul 30, 2011 | Dishwashers
Items in the bottom tray are clean; items in the top are not.
The first thing to check is whether the spray arms are clogged up. Small, hard food particles such as pepper seeds can block the holes. Some spray arms can be removed very easily for cleaning. Our old Kenmore spray arm needed a star-shaped bit. Check the overhead spray arm as well as the ones under the racks. You might also try running Lime-Away through if the inside looks clogged up with calcium deposits.
In our old Kenmore, we had food residue on the top rack when the grinder blade was chipped, broken or obstructed by an olive pit, a date pit or a cherry stone. Don't know why the top was worse than the bottom. A new one cost about $25 at that time and was not to hard to replace, but it is a poor design, since it is nearly impossible to keep such things out of the dishwasher. We replaced the grinder three times in 5 years.
Even though modern dishwashers brag that you don't have to rinse first, it is helpful to knock off seeds and pits that can cause trouble. To save water, have a small vessel of water--perhaps a pan you are soaking--and use a brush to quickly swipe each plate or bowl before loading.
Jul 26, 2011 | KitchenAid Dishwashers
Items still dirty after wash cycle in bottom tray. i opened door after few minutes to have look c and i think the bottom arm isn't moving round. given everything a thorough clean not sure what to do...
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | Bosch Dishwashers
I have a whirlpool dishwasher with three levels of spray arms. Only the bottom arm turns. the other two upper arms do not turn. It appears that some water comes from the middle arm, but it does not...
Usually when you have spray arm problems it is due to two things, Not enough water
entering the unit (fill valve about 20 to 40 dollars), or clogged pump intake.
The easy test for the fill valve is to add some water with a pitcher after it completes
its fill cycle and see if it functions correctly. I have seen many many dishwashers
only a couple years old go to the dump for this inexpensive part.
If plastic or other items
clog the pump intake it may actually get into the control valve and cause the water
to be pumped out as it tries to cycle. After the fill test see how much water is left in
the tank bottom. The last thing is the pump intake , it may be clogged with plastic
or other items. Usually located under the two screws holding the intake cover
There usually is an insert beneath the cover and be careful of glass in the intake sump.
There should be a "macerator" blade or spring at the intake, so be careful of it as well
hope this helps.
Mar 05, 2011 | Whirlpool Dishwashers
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top arm is not moving
Filter and rotor jets prob clogged.
In wash, the water is heated, supposed to dissolve the soap and then sucked thru a filter and pumped up the back and out the top to spray water everywhere.
Soap doesn't always fully dissolve and clogs the filter and some slimy gets thru and clogs the rotor jets.
To fix:
1. Remove Upper and lower dish drawers
2. Take off the Upper. Middle and lotwe rotors and clean their jets out with toothpick and frequent flushing (Plug a clean hole with toothpick to make water come out elsewhere) Use the sink on full blast to see if water comes out all holes.
3. Reassemble rotors.
4. Remove and clean filter. The filter is in the bottom above the Motor/pump and held in with 8 shiny hex-head or Torx screws. Take out all screws, lift out filter and clean in sink with warm or hot water from backside. Use garden hose for hard to reach areas.
5. Reinstall filter. Don't overtighten or you will crack it
6. Replace drawers
Done!
Mar 26, 2009 | Dishwashers
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Lg LDF6810ST dishwasher not cleaning top rack
Almost all of the problems mentioned above will be solved by having the owner buy a name brand detergent powder (like Electrosol or Cascade) and using a little less than you think you should.
For those who continue to have problems with poor cleaning, you need to remove the lower spray arm (pull straight up firmly, then out) and then remove the 9 screws that hold the filter in. Using a flashlight, inspect everywhere in the sump area (be careful of broken glass!) Remove all debris and especially look for something blocking the white check valve that is driven by the Vario motor to control the alternation between the upper sprayer arms and the lower arm. Reasemble and test.
If inside dishwasher is a mess with white mineral deposits, recommend you place a bowl filled with white vinegar on the rack of your empty DW. Start a quick cycle with no detergent added.
Check out how clean it is when you are done!
If you have problems after this, please post back what you are seeing.
Good Luck!
Oct 02, 2008 | LG LDF6810ST Stainless Steel Built-in...
Middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Oct 28, 2007 | GE 24 in. Profile PDW7800 Built-in...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
391 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
